- ${title}
- ${title}
- ${title}
- ${title}
Setting Up the Printer Hardware for HP Color LaserJet Pro M176n MFP Printers
Setting up the printer
Follow these steps in order.
Step 1: Check the contents of the box
Step 2: Remove the packaging and prepare the cartridges
Take the printer out of its box, and then remove the packaging.Figure : Unpack the printer
Place the printer in a sturdy, well-ventilated, dust-free area away from direct sunlight.
Lift the scanner assembly, and then remove the tape and protective foam from underneath.Figure : Lift the scanner assembly
Open the cartridge access door, remove the foam insert, and then pull the two orange rings straight up to remove the cartridge sealing tape.Figure : Open the cartridge access doorFigure : Remove the foam insert, and then pull the two orange rings straight up
Hold the left and right corners of the included setup instructions, and then pull straight up to remove them.Figure : Pull straight up to remove the setup instructions
Recycle the packing material.Figure : Recycle the packing material
Attach the input paper tray (bottom), the output paper tray extender (top), and then lower the scanner assembly.
Attach the output paper tray extender
Lower the scanner assembly
Figure : Attach the input paper tray, the output paper tray extender, and then lower the scanner assembly -
Step 3: Load paper
Follow these steps to load paper in the paper input tray.
Slide the left and right paper width guides all the way to the outside of the paper tray, and then, if necessary, pull the bottom paper width guide as far away from the printer as possible.Figure : Slide the paper width guides outward
Load plain white paper into the paper tray.Figure : Load paper into the paper tray
If necessary, slide the paper width guides inward so that they rest on the edges of the paper.Figure : Slide the paper guides inward
Place the dust cover on the paper tray.Figure : Place the dust cover on the paper tray
Step 4: Adjust the control panel display
Gently lift the control panel display into the preferred position.
Figure : Adjust the control panel display
Step 5: Connect the power cord and turn on the power
Connect the power cord to the rear of the printer.
Plug the power cord into an electrical outlet.Figure : Connect the power cord
Press the Power button to turn on the printer. The printer initializes and calibrates itself.
Wait until the printer is idle and silent before proceeding. Do not connect the USB cable yet.Figure : Do not connect the USB cable yet
Step 6: Select the language
During the initialization, the Language menu displays.
Press the Right Arrow button (
) until your preferred language is displayed, and then press OK.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
