Document ID: c03896513
Version: 1
NOTEBOOK - System BIOS Update F.42 for 5330m
Release date : 13-Aug-2013
Last updated : 13-Aug-2013
DETAILS OF CHANGE
  • Updated the Intel PXE code to version 1.0C.
  • Fixed an issue where the computer stops functioning (hangs) and displays a black screen when the computer is restarted after BitLocker is enabled.
  • Fixed an issue where the Windows Event viewer logs an event ID warning number 24624 when the computer is restarted with BitLocker enabled.
REASON FOR CHANGE
Quarterly refresh for the factory and Web release.
IMPACT OF CHANGE
None.
Components affected:
HP ProBook 5330m Notebook PC
DATE OF CHANGE
Effective date : 15-Jul-2013
Hardware platforms affected : HP ProBook 5330m Notebook PC
