HP Deskjet 4640, Officejet 4630 Printers - Paper Jam Error
This document is for HP Deskjet Ink Advantage 4645, 4646, 4648, Officejet 4630, 4631, 4632, 4634, 4635, 4636, and 4639 e-All-in-One printers.
During printing, the printer stops feeding pages and the error message Paper Jam displays on the printer control panel. The control panel might also display a brief description of how to remove the jammed paper.
Paper jams can be real or false. The printer might report a paper jam even when there is no jammed paper. The following steps apply to both real and false paper jams.
Step 1: Look for jammed paper
Paper jams can occur in multiple areas of the printer. If you cannot find the paper jam in one area, continue to the next area until you locate the jam.
If you have checked and removed any jammed paper from each printer area and the error persists, continue to the next step.
Step 2: Clean the paper rollers
Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues.
  1. Turn off the printer if it is not off already.
  2. Disconnect the power cord from the rear of the printer if it is not disconnected already.
      warning:
    You must disconnect the power cord before reaching inside the printer to avoid risk of injuries or electric shock.
  3. Locate the slots on the left and right sides of the printer.
    Image: Locate the slots on the sides of the printer
  4. Slide your fingers into the two slots, and then gently lift up to open the ink cartridge access door.
    Image: Open the ink cartridge access door.
  5. Locate the paper path cover in the area behind the ink cartridge access area.
    Image: Locate the paper path cover.
  6. To remove the paper path cover, pinch the tabs together, and then lift up.
      Image: Remove the paper path cover.
    1. Pinch the tabs together
    2. Lift up
  7. Lightly dampen a lint-free swab with distilled or bottled water, and then squeeze any excess liquid from the swab.
  8. Press the swab against the rollers inside the printer, and then rotate the rollers upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup.
    Image: Clean the rollers inside the printer
  9. Allow the rollers to dry for 10 to 15 minutes.
  10. Check the rollers on the underside of the paper path cover. Make sure the rollers are not missing, that they turn easily, and that they are springy when you press them. If the rollers are damaged, replace the paper path cover with a new one.
    Image: Check the rollers on the paper path cover
  11. Replace the paper path cover with the spring-loaded tabs facing toward the front of the printer. Gently press the cover down at the left and right edges. The cover clicks into place.
    Make sure both edges of the paper path cover are in place.
    Image: Replace the paper path cover.
  12. Close the ink cartridge access door.
    Image: Close the ink cartridge access door.
  13. Reconnect the power cord to the rear of the printer, and then turn on the printer.
  14. Press OK to clear any messages on the printer control panel.
