Removing and Replacing the Service Door for HP Mini Notebook PCs
This document pertains to HP Mini 1104, 110-4100/4300, 200-4200, 210-4000/4100, and CQ10-1100 series notebook computers.
HP Mini notebook computer
Before you begin
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Mini 1104, 110-4xxx, 200-4xxx, and Compaq Mini CQ10-1xxx series notebook computers.
Removing the service door
  warning:
Follow the steps in this section to remove the service door.
Step 1
Remove the battery.
For more information about removing the battery, refer to the HP support document Removing and Replacing the Battery.
Removing the battery
Step 2
On the bottom of the notebook, slide the battery release latch into the release position to partially eject the service door.
The release latch is identified by a battery icon.
Sliding the battery release latch
Step 3
Slide the service door toward the front of the computer.
Sliding the service door
Step 4
Lift and remove the service door.
Replacing the service door
Use the steps in this section to replace the service door.
Step 1
Align the service door in place.
Aligning the service door
Step 2
Slide the service door towards the front of the computer until it is properly seated and the battery release latch clicks.
Sliding the service door in
Step 3
Replace the battery.
For more information about replacing the battery, refer to the HP support document Removing and Replacing the Battery.
Pressing down on the battery
