HP Designjet T920 and T1500 ePrinter series - Front-panel menu items
Menu item
Sub-menu item
Sub-menu item
Values and Description
TCP/IP
Host Name
An alphanumeric string, up to 32 characters, used to identify the device. This name is listed on the HP Jetdirect configuration page. The default host name is NPIxxxxxx, where xxxxxx is the last six digits of the LAN hardware (MAC) address.
IPV4 Settings
Config Method
Specifies the method that TCP/IPv4 parameters will be configured on the HP Jetdirect print server.
Bootp: Use BootP (Bootstrap Protocol) for automatic configuration from a BootP server.
DHCP (default): Use DHCP (Dynamic Host Configuration Protocol) for automatic configuration from a DHCPv4 server. If selected and a DHCP lease exists, DHCP Release and DHCP Renew menus are available to set DHCP lease options.
Auto IP: Use automatic link-local IPv4 addressing. An address in the form 169.254.x.x is assigned automatically.
Manual: Use the Manual Settings menu to configure TCP/IPv4 parameters.
DHCP Release
This menu appears if Config Method was set to DHCP and a DHCP lease for the print server exists.
No (default): The current DHCP lease is saved.
Yes: The current DHCP lease and the leased IP address are released.
DHCP Renew
No (default): The print server does not request to renew the DHCP lease.
Yes: The print server requests to renew the current DHCP lease.
Manual Settings
(Available only if Config Method is set to Manual) Configure parameters directly from the printer control panel:
IP Address: The unique IP address of the printer (n.n.n.n).
Subnet Mask: The subnet mask for the printer (n.n.n.n).
Syslog Server: The IP address of the syslog server (n.n.n.n) used to receive and log syslog messages.
Default Gateway: The IP address (n.n.n.n) of the gateway or router used for communications with other networks.
Idle Timeout: The time period, in seconds, after which an idle TCP print data connection is closed (default is 270 seconds, 0 disables the timeout).
Default IP
Specify the IP address to default to when the print server is unable to obtain an IP address from the network during a forced TCP/IP reconfiguration (for example, when manually configured to use BootP or DHCP).
Auto IP: A link-local IP address 169.254.x.x is set.
Legacy: The address 192.0.0.192 is set, consistent with older HP Jetdirect devices.
Primary DNS
Specify the IP address (n.n.n.n) of a Primary DNS Server.
This item appears only if Manual configuration is a higher priority than DHCP in the Config. Precedence table, configured through the embedded Web server.
Secondary DNS
Specify the IP address (n.n.n.n) of a Secondary Domain Name System (DNS) Server.
This item will appear only if Manual configuration is a higher priority than DHCP in the Config. Precedence table, configured through the embedded Web server.
IPV6 Settings
Enable
Use this item to enable or disable IPv6 operation on the print server.
Off: IPv6 is disabled.
On (default): IPv6 is enabled.
Address
Use this item to manually configure an IPv6 address.
Manual Settings: Use the Manual Settings menu to enable and manually configure a TCP/ IPv6 address.
Enable: Select this item and choose On to enable manual configuration, or Off to disable manual configuration.
Address: Use this item to type a 32 hexadecimal digit IPv6 node address that uses the colon hexadecimal syntax.
DHCPV6 Policy
Router Specified: The stateful auto-configuration method to be used by the print server is determined by a router. The router specifies whether the print server obtains its address, its configuration information, or both from a DHCPv6 server.
Router Unavailable: If a router is not available, the print server should attempt to obtain its stateful configuration from a DHCPv6 server.
Always: Whether or not a router is available, the print server always attempts to obtain its stateful configuration from a DHCPv6 server.
Primary DNS
Use this item to specify an IPv6 address for a primary DNS server that the print server should use.
This item will appear only if Manual configuration is a higher priority than DHCP in the Config Precedence table, configured through the embedded Web server.
Secondary DNS
Use this item to specify an IPv6 address for a secondary DNS server that the print server should use.
Proxy Server
Specifies the proxy server to be used by embedded applications in the device. A proxy server is typically used by network clients for Internet access. It caches Web pages, and provides a degree of Internet security, for those clients.
To specify a proxy server, enter its IPv4 address or fully-qualified domain name. The name can be up to 255 octets.
For some networks, you may need to contact your Independent Service Provider (ISP) for the proxy server address.
Proxy Port
Type the port number used by the proxy server for client support. The port number identifies the port reserved for proxy activity on your network, and can be a value from 0 to 65535.
Security
Print Sec Page
Yes: Prints a page that contains the current IPsec security settings on the HP Jetdirect print server.
No (default): A security settings page is not printed.
Secure Web
For configuration management, specify whether the embedded Web server will accept communications using HTTPS (Secure HTTP) only, or both HTTP and HTTPS.
HTTPS Required: For secure, encrypted communications, only HTTPS access is accepted. The print server will appear as a secure site.
HTTP/HTTPS optional: Access using either HTTP or HTTPS is permitted.
The factory default setting depends on the print server model.
IPSEC
Specify the IPsec or Firewall status on the print server.
Keep: IPsec/Firewall status remains the same as currently configured.
Disable: IPsec/Firewall operation on the print server is disabled.
Reset Security
Specify whether the current security settings on the print server will be saved or reset to factory defaults.
No (default): The current security settings are maintained.
Yes: Security settings are reset to factory defaults.
Link Speed
The link speed and communication mode of the print server must match the network. The available settings depend on the device and installed print server. Select one of the following link configuration settings:
If you change the link setting, network communications with the print server and network device might be lost.
Auto (default): The print server uses auto-negotiation to configure itself with the highest link speed and communication mode allowed. If auto-negotiation fails, either 100TX HALF or 10TX HALF is set depending on the detected link speed of the hub/switch port. (A 1000T half-duplex selection is not supported.)
10T Half: 10 Mbps, half-duplex operation.
10T Full: 10 Mbps, Full-duplex operation.
100TX Half: 100 Mbps, half-duplex operation.
100TX Full: 100 Mbps, full-duplex operation.
100TX Auto: Limits auto-negotiation to a maximum link speed of 100 Mbps.
1000TX Full: 1000 Mbps, full-duplex operation.
