    Fix Windows 10 Update Issues
Removing and Replacing a Memory Module for HP Pavilion dm1-4000, dm1-4100, dm1-4200, dm1-4300, and dm1-4400 Notebook PCs
This document applies to HP Pavilion dm1-4xxx series notebook computers.
-HP Pavilion dm1-4xxx series notebook computer
Before you begin
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion dm1-4xxx Series PCs.
Removing a memory module
  warning:
Follow the steps in this section to remove a memory module.
Step 1
Remove the battery.
For more information about removing the battery, refer to the HP support document Removing and Replacing the Battery.
Removing the battery
Step 2
Remove the service cover.
For more information about removing the service cover, refer to the HP support document Removing and Replacing the Service Cover.
Removing the service cover
Step 3
Push both arms outward simultaneously to release the memory module to the spring tension position.
Pushing the arms outward
Step 4
Grasp the memory module by the edges and pull up gently to remove it.
Use care to not touch the memory chips when handling a memory module. Touching the memory chips could damage or destroy the memory.
Pulling out the RAM
Step 5
Place a memory module in an anti-static bag.
Placing a memory module in anti-static bag
Replacing a memory module
Use the steps in this section to replace a memory module.
Step 1
Align the notch in a memory module with the key in the memory module slot.
Aligning the notch and key
Step 2
Insert a memory module at an angle into the slot.
Inserting the module
Step 3
Press the memory module down until it latches.
Pushing down on the RAM
Step 4
Replace the service cover.
For more information about replacing the service cover, refer to the HP support document Removing and Replacing the Service Cover.
Sliding the service cover in
Step 5
Replace the battery.
For more information about replacing the battery, refer to the HP support document Removing and Replacing the Battery.
Pressing down on  the battery
