    Fix Windows 10 Update Issues
Removing and Replacing the Battery for HP Pavilion dm1-4000, dm1-4100, dm1-4200, dm1-4300, and dm1-4400 Notebook PCs
This document applies to HP Pavilion dm1-4xxx series notebook computers.
-HP Pavilion dm1-4xxx series notebook computer
Before you begin
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Video overview
For best quality on dial-up connections, wait until the video has fully loaded before viewing.
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion dm1-4xxx Series PCs.
Removing the battery
  warning:
Follow the steps in this section to remove the battery.
Step 1
On the bottom of the notebook, slide and hold the battery release latch into the release position to partially eject the battery.
Sliding the release latch
Step 2
Lift and remove the battery.
Replacing the battery
Use the steps in this section to replace the battery.
Step 1
Align the bottom outer edge of the battery into the battery bay.
Aligning the battery
Step 2
Press down on the inner edge of the battery until it clicks into place.
Pressing down on  the battery
