An 'Incompatible Ink Cartridge or 'Ink Cartridges Missing' Error Message Displays for HP Deskjet 1510 and 2540 All-in-One Printers
This document is for the following printers: HP Deskjet 1510, 1511, 1512, 1513, 1514, 2540, 2541, 2542, 2543, 2544, 2546, 2546B, 2546P, 2546R, 2547, 2548, and 2549; and Deskjet Ink Advantage 1515, 1516, 1518, 2545, 2546, and 2548 printers.
After you install a cartridge, an 'Incompatible Ink Cartridge' or 'Ink Cartridges Missing' error message displays on the computer screen.
One or both of the Cartridge lights on the front panel might be on or blinking.
Solution one: Check the compatibility of your cartridges
Important: Before you begin, make sure that the cartridges are compatible with your printer.
  • If the cartridges are compatible, continue with the solutions in this document.
  • If the cartridges are not compatible, continue to the step to replace the cartridge.
Solution two: Remove, inspect, and then reseat the cartridges
Follow these steps to make sure that the cartridges are inserted correctly.
HP cannot guarantee the quality of remanufactured or refilled ink cartridges. Use genuine HP ink cartridges for good print quality.
  1. If the printer is off, press the Power button to turn on the printer.
  2. Open the ink cartridge access door. The carriage moves to the center of the printer. Wait until the carriage is idle and silent before continuing.
    Image: Open the cartridge access door
  3. Press down on the ink cartridge to release it, and then pull the ink cartridge out to remove it from its slot.
    Image: Remove the cartridge
    Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Image: Do not touch the contacts or nozzles
  4. Remove any protective tape that still might be on the nozzles.
    Do not try to remove the copper electrical strip.
    Image: Remove the protective tape
  5. Hold the ink cartridge by its sides with the nozzles toward the printer, and then insert the ink cartridge into its slot. Make sure that the ink cartridge is inserted in the correct slot.
    • The tri-color ink cartridge goes in the slot on the left.
    • The black ink cartridge goes in the slot on the right.
    Image: Snap the cartridge into place
  6. Push the ink cartridge forward into its slot until it snaps into place.
  7. Repeat these steps to replace the other ink cartridge, if necessary.
  8. Close the ink cartridge access door.
    Image: Close the cartridge access door
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Solution three: Restart the printer
Follow these steps to restart the printer.
  1. Press the Power button () to turn on the product.
  2. With the product turned on, disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on by itself, press the Power button () to turn it on.
Solution four: Clean the cartridge contacts
Follow these steps to clean the contacts on the cartridge and in the cartridge slot.
Clean the ink cartridges one at a time. Do not leave an ink cartridge outside the printer for more than 30 minutes.
  1. Gather the following materials:
    • Dry foam-rubber swabs, lint-free cloth, or any soft material that does not come apart or leave fibers (coffee filters work well)
    • Distilled, filtered, or bottled water (tap water might contain contaminants that can damage the ink cartridges)
      Do not use platen cleaners or alcohol to clean the ink cartridge contacts. These can damage the ink cartridge or the printer.
  2. Press the Power button to turn on the printer.
  3. Open the ink cartridge access door. The carriage moves to the center of the printer. Wait until the carriage is idle and silent before continuing.
  4. Disconnect the power cord from the rear of the printer.
  5. Press down on the ink cartridge to release it, and then pull the ink cartridge out to remove it from its slot.
    Do not remove both ink cartridges at the same time. Remove and clean each ink cartridge one at a time. Do not leave an ink cartridge outside the printer for more than 30 minutes.
  6. Hold the ink cartridge by its sides.
    Image:  Hold the cartridge by its sides
  7. Inspect the contacts for ink and debris buildup.
  8. Wipe the contacts with a dry swab or other lint-free material until no debris remains on them.
    Be careful to wipe only the contacts. Do not smear any ink or debris elsewhere on the ink cartridge.
  9. Dip a clean foam-rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it.
  10. Clean only the copper-colored contacts, and then allow the ink cartridge to dry for approximately 10 minutes.
      Image: Clean the contacts
    1. Copper-colored contacts
    2. Ink nozzles (do not clean)
  11. Lightly moisten another cotton swab with distilled water, and then squeeze any excess water from the swab.
  12. Use the swab to clean the electrical contacts in the carriage, located inside the printer.
  13. Clean the contacts in the carriage.
    Image: The carriage contacts
  14. Either let the ink cartridge sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
    Make sure that the ink cartridge is not left out of the printer for more than 30 minutes.
  15. Hold the ink cartridge by its sides with the nozzles toward the printer, and then insert the ink cartridge into its slot. Make sure that the ink cartridge is inserted in the correct slot.
  16. Push the ink cartridge forward into its slot until it snaps into place.
  17. Repeat these steps to clean and then reinsert the other ink cartridges.
  18. Close the ink cartridge access door.
  19. Reconnect the power cord to the rear of the printer.
  20. Press the Power button to turn on the printer if it does not turn on automatically.
Solution five: Remove and then reinsert the cartridges again
Repeat the steps that you performed earlier in this document to remove and then reinsert the cartridges.
Make sure that the cartridges snap firmly into place.
Solution six: Clean the cartridge contacts again
Cleaning the cartridge contacts again can help resolve the issue. Repeat the steps that you performed earlier in this document to clean the contacts of the cartridges.
Solution seven: Replace the cartridge
Follow these steps to replace the cartridge or cartridges indicated by the blinking light.
If you have a defective cartridge or printhead, it might be under warranty. To check the warranty on your ink or toner supplies, go to hp.com/go/learnaboutsupplies, and then review the limited warranty information for your supplies.
Video of replacing the cartridges
The following video demonstrates how to replace an ink cartridge.
This video shows the HP Deskjet 1510 e-All-in-One printer, but the steps are the same for your printer.
Step one: Replace the cartridge
  1. Press the Power button to turn on the printer, if it is not already turned on.
  2. Load plain white paper into the input tray.
  3. Open the ink cartridge access door. The carriage moves to the center of the printer. Wait until the printer is idle and silent before continuing.
  4. Lightly press down on the ink cartridge to release it, and then pull the ink cartridge out of its slot.
  5. Remove the new ink cartridge from its packaging, and then pull the orange tab to remove the plastic tape.
    Image: Remove the plastic tape and do not touch the contacts or ink nozzles
  6. Hold the ink cartridge by its sides with the nozzles toward the printer, and then insert the ink cartridge into its slot. Make sure that the ink cartridge is inserted in the correct slot.
    Image: Insert the cartridge into its slot
  7. Push the ink cartridge forward into its slot until it snaps into place.
  8. Repeat these steps to replace the other ink cartridge, if necessary.
  9. Close the ink cartridge access door.
  10. Follow any prompts on the screen.
  11. Wait about 30 seconds for the alignment page to automatically print.
    Image: The alignment page prints automatically after 30 seconds
    The printer prints an alignment page automatically only when a new ink cartridge has been installed.
Step two: Align the cartridges
  1. Lift the scanner lid.
  2. Place the alignment page with the print side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment page.
    Image: Place the alignment page on the scanner glass
  3. Close the scanner lid.
  4. Press the Start Copy Black button or the Start Copy Color button on the front panel of the printer. The printer aligns the ink cartridges.
Solution eight: Service the printer
