This document is for HP Deskjet 1510, 1511, 1512, 1513, 1514, Deskjet Ink Advantage 1515, 1516, and 1518 All-in-One printers.
- ${title}
- ${title}
- ${title}
- ${title}
HP Deskjet 1510 Printers - Attention Light Blinks (Paper Jam)
During printing, the printer stops feeding pages, and the Attention light on the printer's front panel blinks. This indicates that paper might be jammed inside the printer.
The Attention light
note:Paper jams can be real or false. The printer might report a paper jam even when there is no jammed paper. The following steps apply to both real and false paper jams.
Video of clearing a paper jam
The following video demonstrates how to clear a paper jam.
note:This video shows the HP Deskjet 1510 e-All-in-One printer, but the steps are the same for your printer.
Step 1: Clear the jam from the printer
Paper jams can occur in multiple areas of the printer. If you cannot find the paper jam in one area, continue to the next area until the jam is located.
If you have checked and removed any jammed paper from each printer area and the error persists, continue to the next step.
Step 2: Make sure the carriage can move freely
Make sure the carriage moves freely across the width of the printer. check for any paper or objects that might restrict the carriage.
Turn on the printer, if it is not already on.
Open the ink cartridge access door.
Wait until the carriage is idle and silent before you continue.
With the printer turned on, disconnect the power cord from the rear of the printer.
warning:
You must unplug the power cord to move the carriage by hand and reset the paper feed mechanism without the risk of electrical shock. -
Check for any paper or objects that might be restricting the carriage, and then remove any paper or objects that you find.
If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the printer. If pieces of paper remain in the printer, more paper jams can occur. -
Reach inside the printer through the ink cartridge access door, and then manually move the carriage.
If the carriage is stuck on the right side of the printer, move the carriage to the left side of the printer.
If the carriage is stuck on the left side of the printer, move the carriage to the right side of the printer.
If the carriage is stuck in the middle of the printer, move the carriage to the right side of the printer.
Remove any loose paper or obstructions found.
Make sure the carriage can move freely across the width of the printer. Firmly push the carriage to the left side of the printer, and then to the right side.
Reconnect the power cord to the rear of the printer, and then turn on the printer.
Try to print. If the error persists, continue to the next step.
Step 3: Use an automated tool to clean ink smears
Clean ink smears from the printer control panel.
Press the Power button to turn on the printer.
Load paper in the input tray.
Press and hold the Power button, press the Cancel button
three times, press the Color Copy button
eight times, and then release the Power button.
The printer slowly feeds one page. The printer makes mechanical noises for about 1 minute. Wait until the paper is out of the printer.
Step 4: Use an automated tool to clean the paper rollers
Clean the paper rollers from the printer control panel.
- Press the Power button to turn on the printer.
Remove the paper from the input tray.
seven times, and then release the Power button.
The printer makes mechanical noises for about 1 minute. Wait until the printer stops making noises.
Step 5: Manually clean the paper rollers inside the ink cartridge access area
Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues.
Turn off the printer, and then disconnect the power cord.
warning:
Disconnect the power cord before reaching inside the printer to avoid risk of injuries or electric shock. -
Raise the input tray.
Look down through the open input tray and find the gray paper pick rollers. You might need a flashlight to illuminate the area.
Lightly dampen a lint-free cloth with distilled water, and then squeeze any excess liquid from the cloth.
Press the cloth against the rollers and rotate them upward with your fingers. Apply a moderate amount of pressure to remove dust or dirt buildup.
Allow the rollers to dry completely (approximately 10 minutes).
Reconnect the power cord and any cables to the rear of the printer, and then turn on the printer.
Step 6: Reset the printer
Sometimes a paper jam error persists even though there is no jammed paper (false paper jam). Follow these steps to reset the HP printer, which will clear a false paper jam error.
Unplug the power cord from the wall outlet.
Wait at least 15 seconds.
Plug the power cord back into the wall outlet.
Reconnect the power cord to the printer.
Turn the printer on.
Step 7: Service the printer
Follow these steps if you have completed all the preceding steps and are still experiencing a problem.
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
