HP ZR2330w 23-inch IPS LED Backlit Monitor - Overview
Product description
The HP ZR2330w 23-inch IPS LED Backlit Monitor features advanced connectivity, a fully adjustable design and remarkable IPS screen performance perfect for multi-monitor setups and budget-conscious businesses.
Product features
Feature
Model
ZR2330w
Spare part number
707405-001
Type
IPS (in-plane switching) LED Backlit LCD
Viewable Image Area (Display)
58.42 cm (23 in) widescreen; diagonally measured
Color Support
Over 16 million colors (through FRM)
White LED Backlights
Yes
Tilt capability
-5° to 30°
Pivot Rotation
Yes
Input Connectors
  • SVGA (analog), DVI-D and DisplayPort w/ HDCP
  • 75 Ohms (VGA)
  • Supports DisplayPort digital (cables are provided with select models).
On-Screen Display (OSD) adjustments
Several languages for easy setup and screen optimization
Swivel and height adjustment capabilities
360°
Color
Black
Security Lock-Ready
Yes
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
