Document ID: c03721265
Version: 1
HP Z Series Workstations - Changes to HP's Windows 7 Software Offerings in April 2013
Release date : 29-Mar-2013
Last updated : 12-Apr-2013
DETAILS OF CHANGE
Effective April 1, 2013, HP is changing the software configuration on HP Z Series Workstations that come with Windows 7 Professional, Windows 7 Home Premium (Z220 Convertible Minitower and Z220 Small Form Factor Workstations only), or Windows 7 Ultimate (64-bit) (HP Z420, Z620, and Z820 Workstations only). The new software addition and updates are being made available for download from HP’s support website for owners of existing Z220 Convertible Minitower, Z220 Small Form Factor, Z1, Z420, Z620, and Z820 Workstations.
HP Z1 Workstation BIOS version 02.57 has the following enhancements added:
  • Updated the PXE OROM to build 091.
  • Fixed an issue where after a BIOS update the BIOS version string is not updated after the reset.
HP Z220 Convertible Minitower and Z220 Small Form Factor Workstation BIOS version 01.58 has the following enhancements added:
  • Applying factory defaults no longer hide Embedded Security.
  • Fixed Drive Lock cannot work when Storage Option ROMs set to UEFI Only.
  • Fixed disk information lost when Secure Boot set to enabled.
  • Fixed NIC Option ROM Download cannot be disabled by HP Performance Advisor.
sourceInformation
COMPONENT VERSION
There are several components. See components affected section below.
REASON FOR CHANGE
To update HP Z Series Workstation models with the latest component software.
IMPACT OF CHANGE
There is no known impact to the customer.
Components affected:
  • The following components have been updated:
    • CyberLink Power2Go version 8.0.2.2321 or later
    • CyberLink PowerDVD version 10.0.7.4721 or later
    • HP Performance Advisor version 1.5.4924.0 or later
    • HP Remote Graphics Software version 6.0.0 or later
    • PDF Complete Corporate Edition version 4.1.9 or later
    • Windows 7 Restore Media (HP Z1 Workstations only)
    • HP Z1 Workstation BIOS v02.57
    • HP Z220 Convertible Minitower and HP Z220 Small Form Factor Series Workstation BIOS v01.58
REVISION HISTORY : Version 1
DATE OF CHANGE
Effective date : 01-Apr-2013
Hardware platforms affected : HP Z1 Workstation, HP Z220 Convertible Minitower Workstation, HP Z220 Small Form Factor Workstation, HP Z420 Workstation, HP Z620 Workstation, HP Z820 Workstation
