Document ID: c03719287
Version: 1
HP 6360t Mobile Thin Client Notebook PCs - ThinState Automatically Enables HP Logon Manager
Release date : 27-Mar-2013
Last updated : 27-Mar-2013
DESCRIPTION
The HP Logon Manager automatically turns on after ThinState deploys the operating system image.
SCOPE
RESOLUTION
To disable the automatic logon feature for both the original notebook and future use, follow these steps:
  1. Log on with Administrator privileges.
  2. Click Start, click Control Panel, then double-click HP Logon Manager.
  3. In the Windows Logon Configuration dialog box, clear the Enable Logon box, click OK.
  4. Click Start, click Computer, then click Local Disk (C:).
  5. Double-click Windows, double-click Setup, double-click Scripts, then right-click _AdminAutologon.cmd and select Delete from the context menu.
  6. Click Yes.
  7. Right-click _UserAutologon.cmd, then select Delete.
  8. Click Yes.
  9. Restart the notebook.
Hardware platforms affected : HP 6360t Mobile Thin Client
Support Communication Cross Reference ID : IA03719287
