HP Scanjet Pro 3000 s2 - Sleep Mode and auto-off settings
By default, the scanner will enter Sleep Mode after 15 minutes of inactivity, and will turn off automatically after two hours of inactivity to conserve power.
Windows: To change the default sleep and auto-off settings, complete these steps:
  1. Start the HP Scanner Tools Utility by doing one of the following:
    • Double-click the HP Easy Scan icon on your desktop, click the Scanner drop-down menu, and then click Scanner Settings.
    • Windows XP, Vista, Windows 7: Click Start, point to Programs or All Programs, point to HP, point to Scanjet, point to 3000 s2, and then click Scanner Tools Utility.
    • Windows 8: On the Start screen, click the HP Scanner Tools Utility tile.
  2. Click the Settings tab, and then select the appropriate sleep mode and auto-off settings.
    If you set both Sleep Mode and auto-off to 1 hour, the scanner will automatically turn off after one hour.
    • To specify the period of inactivity after which the scanner goes into Sleep Mode, select 15 minutes or 1 hour from the Sleep: Put the scanner to sleep after: drop-down list.
    • To specify the period of inactivity after which the scanner automatically turns off, select the appropriate value (1 hour, 2 hours, 4 hours, or Never) from the Auto-Off: Turn off the scanner after: drop-down list.
Mac: Use HP Utility to change the default sleep and auto-off settings.
