HP MP6 Digital Signage Player - Specifications
Physical specifications
Weights & Dimensions (configured with 1 HDD & 1 ODD)
Feature
Chassis (H x W x D)
66 x 252 x 254 mm (2.6 x 9.9 x 10 in)
System volume
4.2 L (257.5 cu in)
System weight
3.1 kg (6.8 lb)
Max supported weight (desktop orientation)
35.0 kg (77.0 lb)
Tower stand (H x W x D)
27 x 125 x 170 mm (1.1 x 4.9 x 6.7 in)
Packaging (H x W x D)
218 x 398 x 500 mm (8.6 x 15.7 x 19.7 in)
Shipping weight
6.5 kg (14.4 lb)
Palletization profile
6-units per layer
10-layer max
60-units per pallet
Power supply specifications
Feature
Standard efficiency
N/A
High efficiency
Integrated graphics: 135W active PFC 87% efficient
Discrete graphics: 180W active PFC 87% efficient
Operating voltage range
90 - 264 V ac
Rated voltage range
100 - 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency range
47 – 63 Hz
Rated input current
N/A
Rated input current with energy efficient power supply
135W : 2.4A
180W : 2.9A
Current leakage (NFPA 99)
Less than 250 µA
Power supply fan
N/A
Power cord length
N/A
External Power Adapter
Dimensions: 6.7 x 2.6 x 1.5 in
Total cord length: 12 ft 8 in
Audio specifications
Feature
Descritpion
Type
Integrated
HD Stereo codec
Realtek 2-channel ALC221 codec
Audio I/O ports
  • Front microphone-In (150-K ohm Input Impedance)
  • Rear Line-In/Microphone input (150-K ohm Input Impedance, function is configurable by audio driver)
  • Rear Line-Out (190 ohms Output Impedance, expects at least a 10-K ohm load)
  • Front Headphone-Out (0.5 Ohm Output Impedance, expects at least a 32 ohm load)
  • Front Microphone/Headphone jack is re-task able to provide Microphone input, line-in or
  • Headphone output to support connecting two headphones to the front of the system. When configured as a second front headphone output, both front headphone outputs are always driven with the same signal.
  • All ports are 3.5 mm
Internal speaker amplifier
1.5W amplifier for the internal speaker only. External speakers must be powered externally. Rear Line-in audio port is re-taskable as either Line-in or Microphone-In.
Multi-streaming capable
Multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes – Uses OS soft wavetable
Analog audio
Yes
Number of Channels on Line-Out
Stereo (Left and right channels)
Internal speaker
Yes
External speaker jack
Yes
Input/Output devices specifications
HP USB standard keyboard
Feature
Physical characteristics
Keys:
104, 105, 106, 107, 109 layout (depending upon country)
Dimensions (L x W x H):
45.8 x 16.3 x 2.5 cm (18.0 x 6.4 x 0.98 in)
Weight:
0.9 kg (2 lb)
Electrical
Operating voltage:
+ 5VDC ± 5%
Power consumption:
50-mA maximum (with three LEDs On)
System interface:
USB Type A plug connector
ESD:
CE level 4, 15-kV air discharge
EMI - RFI:
Conforms to FCC rules for a Class B computing device
Microsoft PC 99 - 2001:
Functionally compliant
Mechanical
Languages:
38 available
Keycaps:
Low-profile design
Switch actuation:
55-g nominal peak force with tactile feedback
Switch life:
20 million keystrokes (using Hasco modified tester)
Switch type:
Contamination-resistant switch membrane
Key-leveling mechanisms:
For all double-wide and greater-length keys
Cable length:
1.8 m (6 ft)
Mechanically compliant
Acoustics:
43-dBA maximum sound pressure level
Environmental
Operating temperature:
10° to 50° C (50° to 122° F )
Non-operating temperature:
-30° to 60° C (-22° to 140° F)
Operating humidity:
10% to 90% (non-condensing at ambient)
Non-operating humidity:
20% to 80% (non-condensing at ambient)
Operating shock:
40 g, six surfaces
Non-operating shock:
80 g, six surfaces
Operating vibration:
2-g peak acceleration
Non-operating vibration:
4-g peak acceleration
Drop (out of box):
66 cm (26 in) on carpet, six-drop sequence
Drop (in box):
107 cm (42 in) on concrete, 16-drop sequence
Approvals
  • UL
  • CSA
  • FCC
  • CE Mark
  • TUV
  • TUV GS
  • VCCI
  • BSMI
  • C-Tick
  • MIC
Ergonomic compliance
  • ANSI HFS 100
  • ISO 9241-4
  • TUVGS
Kit contents
  • Keyboard
  • Installation guide
  • Warranty card
  • Safety and comfort guide
HP USB optical mouse
Feature
Dimensions (H x L x W)
3.8 x 11.6 x 6.3 cm (1.5 x 4.5 x 2.5 in)
0.12 kg (0.27 lb)
Cable length
185 cm (72.8 in)
System requirements
Available USB port
Environmental specifications
Feature
Temperature range
Operating:
  • 10° to 35° C (50° to 95° F)
Non-operating:
  • -30° to 60° C (-22° to 140° F)
Relative humidity
Operating:
  • 10% to 90% (non-condensing at ambient)1
Non-operating:
  • Non-operating: 5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
Operating:
  • 3048 m (10,000 ft)
Non-operating:
  • 9144 m (30,000 ft)
1: Operating temperature is de-rated 1.0 deg C per 300 m (1000 ft) to 3000 m (10,000 ft) above sea level, no direct sustained sunlight. Maximum rate of change is 10 deg C/Hr. The upper limit may be limited by the type and number of options installed.
Network specifications
Intel 82579LM GbE network connection (integrated)
Feature
Connector
RJ-45
System interface
Integrated on PCA
Controller
Intel 82579LM GbE platform LAN connect networking controller
Memory
24KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mbps
IEEE Compliance
802.1P, 802.1Q, 802.2, 802.3, 802.3ab, 802.3az and 802.3u
Bus architecture
PCI Express and SMBus
Data transfer mode
PCIe-based interface for active state operation (S0 state) and SMBus for host and management traffic (Sx low power state)
Power requirement
Requires 3.3V and 1.05V or just 3.3V with integrated regulators
Power consumption 0.697 Watts
Boot ROM support
Yes
Network transfer mode
  • Full-duplex
  • Half-duplex (not supported for the 1000BASE-T transceiver)
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mbps
  • 10BASE-T (full-duplex) 20 Mbps
  • 100BASE-TX (half-duplex) 100 Mbps
  • 100BASE-TX (full-duplex) 200 Mbps
  • 1000BASE-T (full-duplex) 2000 Mbps
Environmental
Operating Temperature: 0° to 85° C
Operating Humidity: 60% RH
Management
WOL, auto MDI crossover, PXE, Muti-port teaming, RSS, Advanced cable diagnostic.
Alerting
ASF 2.0 support
AMT 7.0 support
Intel Centrino Advance-N 6205 Wireless Network Interface Connection
Feature
Wireless LAN standards
  • IEEE 802.11a/b/g/n
  • IEEE 802.11 e, 802.11i, 802.11d, 802.11d, 802.11h
Interoperability
  • Wi-Fi certified (802.11 a/b/g/n WMM, WPA, WPA2 and WPS)
  • Tested with wireless access points from several major manufacturers
  • OS compatible with Microsoft Windows, Win7 and XP
  • Cisco Compatible Extensions Program compliant (802.11a/b/g only) with Microsoft Windows XP and Windows 7
Frequency band
2.4 GHz and 5 GHz
Antenna structure
2 transmit
2 receive (2x2)
Data rates
  • 802.11b: 1, 2, 5.5, 11 Mbps
  • 802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11n: 66 possible data rates, ranging from 6 Mbps to 300 Mbps, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
Modulation
Direct Sequence Spread Spectrum
DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES (support for key sizes of 128bits), TKIP, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP, MSCHAP, PEAP-MSCHAPv2, LEAP, EAP-FAST, EAP-SIM, EAP-AKA PAP, CHAP, TLS, GTC
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows XP only.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
  • Intel My Wifi Technology (iPAN)
Roaming
Provide seamless roaming between like access points (same frequency band)
Output power (for CCK)
15 dBm
Output Power (for OFDM; power varies by data rate)
15 dBm
Power consumption
  • Transmit: 2.3 Watts (average, with one spatial streams)
  • Receive: 1.9 Watts (average with two receive chains)
  • Idle mode: 30mW – 40mW (average)
  • Radio off: 20 mW (max)
Power management
ACPI compliant power management
802.11 compliant power saving mode
Antenna connections
Three U.FL type connectors, 50 ohm nominal impedance
Range
802.11 a - Typical (at 6 Mbps)
  • 600 feet - Outdoor open area
  • 150 feet - Indoor, office environment
802.11 b - Typical (at 1 Mbps)
  • 1200 feet - Outdoor open area
  • 300 feet - Indoor, office environment
802.11 g - Typical (at 1 Mbps)
Form factor
MiniPCI-Express
4.0 g (0.013 lb)
Dimensions
26.8 x 30.0 mm (1.1 x 1.2 in)
Operating voltage
3.3 V +/- 9%
1.5 V +/- 5%
Temperature
Operating: 0° to 80° C (32° to 176° F)
Non-operating: -40° to 80° C (-40° to 176° F)
Humidity
Operating: 10% to 90% (non-condensing)
Non-operating: 5% to 90% (non-condensing)
Configuration utility
Microsoft Windows WES7
Intel IHV extensions for Win7 available to support Cisco Compatible Extensions
Processors
Feature
Intel 3rd Generation Core i7 processors
  • Intel Core i7-3770S processor
  • Up to 3.9 GHz Max turbo frequency (3.1 GHz base frequency)
  • 8MB cache, 4 cores, 8 threads
  • Intel HD Graphics 4000
  • Supports DDR3 memory up to 1600 MT/s data rate
  • Supports Intel vPro Technologies and Intel's Stable Image Platform Program (SIPP)
Intel 3rd Generation Core i5 processors
Intel Core i5-3475S processor
  • Up to 3.6 GHz Max. turbo frequency (2.9 GHz base frequency)
  • 6MB cache, 4 cores, 4 threads
Intel Core i5-3470S processor
  • Intel HD Graphics 2500
Intel 3rd Generation Core i3 processors
Intel Core i3-3225 processor
  • 3.3 GHz base frequency, 3MB cache, 2 cores, 4 threads
Intel Core i3-3240
  • 3.4 GHz base frequency, 3MB cache, 2 cores, 4 threads
Ports
I/O ports – Standard
Feature
USB 3.0
Four each (rear)
PS/2
Two each (color-coded support for keyboard (purple) and mouse (green)
Video
One each VGA and two each DislayPort 1.1a (for integrated dual digital monitor support)
Audio1
Front – microphone & headphone
Rear – line input, line out
All ports are 3.5mm in diameter
NIC
One each RJ-45
1: See Audio/Visual section for information on re-taskable audio ports.
Slots
Feature
PCI Express Mini Card
One each
MXM
One each
Conventional PCI
Revision 2.3
5 V
N/A
PCI Express x1
N/A
PCI Express x16 (wired as x4)
N/A
PCI Express x16
N/A
Graphics specifications
Intel HD graphics
Feature
DisplayPort
Integrated, multi-mode capable
supports HDCP and audio over DisplayPort
Bus type
Intel Flexible Display Interface (Intel FDI)
Memory
32MB is pre-allocated for graphics use at system boot time.
Maximum graphics memory1
Microsoft Windows Embedded
Standard 7
Up to 1.7GB
Multi-display support
Support for DVI, HDMI, dual link DVI or second VGA monitor provided by optional HP DisplayPort adapters.
HW video decode
  • AVC
  • VC1
  • MPEG2
  • JPEG
  • MJPEG
  • PAVP
Maximum color depth
32 bits/pixel
1: The actual amount of maximum graphics memory can be less than the amounts listed above depending upon the computer's configuration.
AMD Radeon HD 7650A graphics card
Feature
Form factor
MXM 3.0
Graphics controller
AMD Radeon HD 7650A
Core clock
600 MHz
Memory clock
800 MHz
Maximum power
35 W
HDCP support
Yes
Display maximum resolution
Digital 2560 x 1600
Analog 2048 x 1536
Supported graphics APIs
DX11, OpenGL 4.1
Display support
Maximum number of simultaneous displays: Four DisplayPort Multistreaming and HBR2 supported DisplayPort audio supported for one audio stream
Hard disk storage specifications
HP 320GB 7.2 K SATA 6.0 Gb/s 2.5 inch Hard Disk Drive
Feature
Capacity
320,072,933,376 bytes
Rotational speed
7,200 rpm
Interface
Serial ATA 2.0 (3.0 Gb/s)
Buffer size
16MB
Logical blocks
488,397,168
Seek time (typical reads, includes controller overhead, including settling)
Single Track: 2.0 ms
Average: 12 ms
Full-Stroke: 22 ms
Height (nominal)
0.374 in/9.5 mm
Width (nominal)
Media diameter: 2.5 in/63.5 mm
Physical size: 2.75 in/70 mm
5° to 55° C (41° to 131° F)
HP 500GB 7.2 K SATA 6.0 Gb/s 2.5 inch Hard Disk Drive
Feature
Capacity
500,107,862,016 bytes
Rotational speed
7,200 rpm
Interface
Buffer size
16MB
Logical blocks
976,773,168
Average: 12 ms
Full-Stroke: 25 ms
Height (nominal)
0.374 in/9.5 mm
Width (nominal)
HP 120GB Solid State Drive
Feature
Unformatted capacity
120GB
Architecture
Multi Level Cell (MLC) NAND Flash with wear leveling 10 channel controller
Interface
Dimensions (W x H x D)
2.74 x 0.37 x 4 in/6.98 x 0.95 x 10.2 cm
0.18 lb/80 g
Bandwidth performance
Sustained sequential read: Up to 250MB/s
Sustained Sequential Write: Up to 70MB/s
Random read: Up to 35K IOPs
Random write: Up to 6.6K IOPs
Latency
Read: 65 ms
Write: 85 ms
Power
DC power requirement: 5 VDC 5%-100 mV ripple p-p
Total power consumption: 0.15W (active); 0.075W (idle)
Useful drive life
35TB written, up to 20GB/day for 5 years
Environmental (all conditions, non-condensing)
Operating temperature: 0° to 70° C (32° to 158° F)
Relative humidity: 5% to 95%
Maximum wet bulb temperature (operating): 29° C (84° F)
Shock: 1,500 G/0.5 ms
Shock: 1,500 G/1.0 msec
HP 256-GB Self-encrypting Solid State Drive
Feature
256GB
Architecture
Multi Level Cell (MLC) NAND Flash with a single-chip controller
Interface
Serial ATA (SATA) (6.0 Gb/s)
2.75 x 0.275 x 3.95 in/6.985 x 0.7 x 10.05 cm
Weight (Max unpackaged)
0.16 lb/73 g
Sustained sequential 128k read: Up to 450 MB/s
Sustained sequential 128k write: Up to 260 MB/s
Random 4k read: Up to 46K IOPS
Random write: Up to 56K IOPS
Latency
Read: 55 ms
Write: 55 ms
Power
Voltage input: 4.5 V (min); 5.5 V (max)
Total power consumption (average): 160 mW (active); less than 85 mW (idle)
Useful Drive Life
72TB written, up to 40GB/day for 5 years
Operating Temperature: 0° to 70° C (32° to 158° F)
Non-operating Temperature:-40° to 85° C (-40° to 185° F)
Relative Humidity: 5% to 95%
Memory configuration
Total memory
Socket
Channel A (black)
Channel B (black)
2GB (single channel)
2GB
Unpopulated
4GB (dual channel)
2GB
2GB
8GB (dual channel)
4GB
4GB
16GB (dual channel)
8GB
8GB
