HP ProDisplay P191 18.5-inch LED Backlit Monitor - Specifications
Physical specifications
Dimensions (W x D X H)
  • Unpacked w/stand: 44.93 x 14.3 x 34.1 cm (17.69 x 5.62 x 13.43 in)
  • Unpacked w/o stand (head only): 44.93 x 4.75 x 27.5 cm (17.69 x 1.87 x 10.86 in)
  • Packaged: 51.5 x 12.8 x 40.2 cm (20.28 x 5.04 x 15.83 in)
  • Base area (footprint): 21.49 x 14.3 cm (8.46 x 5.62 in)
  • Head only: 2.76 kg (6.08 lb)
  • Unpacked: 3.2 kg (7.1 lb)
  • Packaged: 4.2 kg (9.3 lb)
Tilt range
-5° to +25°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Ships detached
Environmental specifications
Temperature
Operating (writing to optical disc)
5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
20% to 80%
Non-operating
5% to 95%, 60°C max wet-bulb
Altitude
Operating
+0 to 5,000 m (16,404 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-Free glass
Yes
BFR/PVC free
Yes (everything except external cables)
Mercury free
Yes
Applicable product safety standards specify thermal limits for plastic surfaces. The device operates well within this range of temperatures.
On Screen Display (OSD) controls
Buttons or Switches
Menu, Minus ("-"), Plus ("+"), OK/Auto and Power
Languages
English, French, German, Italian, Dutch, Spanish, Japanese, Portuguese, Traditional Chinese, and Simplified Chinese
User controls
Brightness, contrast, positioning, color temperature (6500K 9300K, custom), individual color control, serial number, display, clock, clock phase, monitor management, factory reset.
Signal interface/performance
Horizontal frequency
24 to 83 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1366 x 768 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 640 x 480 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 800 x 600 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1280 x1024 @ 60 Hz
  • 1366 x 768 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
140 MHz
User programmable modes
Yes (10)
Anti-Glare
Yes
Default color temperature
6500K
Video/Other inputs
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
75 Ohms
Sync input
TTL separate synch
Video cable
One 15-pin D-sub (VGA)
Video cable lengths
1.8 m (5.9 ft)
Audio
No
Audio cable length
N/A
Power specifications
Power supply
Internal
Input power
100 to 240 V ac, 50 or 60 Hz
Typical power consumption
18 W
Maximum
20 W
Power saving
< 0.5 W
Power cable length
1.9 m (6.2 ft)
Energy consumption
State
115 V ac (60 Hz)
230 V ac (50 Hz)
100 V ac (60 Hz)
Normal operation
9 W
9.6 W
N/A
Sleep
0.29 W
0.38 W
N/A
Off
0.21 W
0.27 W
N/A
Heat dissipation
State
115 V ac (60 Hz)
230 V ac (50 Hz)
100 V ac (60 Hz)
Normal operation
30.78 BTU/hr
32.832 BTU/hr
N/A
Sleep
0.9918 BTU/hr
1.2996 BTU/hr
N/A
Off
0.7182 BTU/hr
0.9234 BTU/hr
N/A
Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
