HP PCs and Printers - Is Windows on My Computer 32-bit or 64-bit?
This document applies to HP products and software for Windows operating systems only. This document does not pertain to Mac, Linux or other non-Windows operating systems.
Some software and drivers install only in a 32-bit or 64-bit version of Windows. Know your Windows version so that you can download the correct type of software and drivers from the HP website.
If you are looking for a printer driver, go to 123.hp.com.
