This document contains steps for replacing the cartridge in your HP printer.
- ${title}
- ${title}
- ${title}
- ${title}
HP Officejet Pro 3610 and 3620 Black & White e-All-in-One Printer Series - Replacing the Cartridge
Replacing the cartridge
Follow these steps to replace the cartridge in the HP printer.
Press the Power button to turn on the printer, if it is not already on.
Open the cartridge access door.Figure : Open the cartridge access door
Push in on the front of the cartridge to release it, and then pull it toward you to remove it from its slot.Figure : Remove the cartridge from its slot
Remove the new cartridge from its packaging.
Hold the cartridge so that the cartridge contacts face toward the printer.
Slide the new cartridge into its slot, and then gently push it forward until it clicks into place.Figure : Insert the cartridge into its slot
Close the cartridge access door.Figure : Close the cartridge access door
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
