HP Officejet X Printer Series - Adobe applications do not print with HP UPD
Issue:
When using a newly added printer with the HP UPD print driver, the first PDF print job from an Adobe application does not print.
Workaround
Send the print job a second time and the job should print. Additional print jobs will print correctly.
Cause
This issue is caused by a capability issue between Adobe applications and HP’s UPD print driver. The issue only occurs for the first print job after HP’s UPD print driver is installed.
