HP ProBook 6570b Notebook PC - Removing and Replacing the Battery
This document pertains only to the HP ProBook 6570b Notebook PC with the following case design:
This document is provided to assist in removing and replacing the battery for the HP ProBook 6570b Notebook PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the battery that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
9-cell, 100-Wh, 3.0-Ah
631243-001
Yes
9-cell, 73-Wh, 2.2-Ah
634089-001
Yes
6-cell, 62-Wh, 2.8-Ah
628668-001
Yes
6-cell, 55-Wh, 2.8-Ah
628670-001
Yes
3-cell, 31-Wh, 2.8-Ah
628664-001
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Battery removal instructions
To view a video demonstrating the procedure for removing/replacing the battery,click here to view the HP Services Media Libraryand then click on Remove/Replace videos. On the new window, select Battery from the menu on the upper left hand side of the screen.
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to the product or loss of data.
Step
Procedure
Instruction
1
On the bottom of the notebook, slide the battery release latch (identified with a battery icon) to the release position and Slide the battery out of the battery bay.
Battery replacement instructions
Step
Procedure
Instruction
To avoid damaging the battery locking mechanism, be sure that the battery release latch is in the unlocked position.
1
Slide the battery into the battery bay until it is properly seated and the battery release latch clicks and Slide the battery release latch to the locked position to secure the battery in the battery bay.
Any red visible under the battery release latch indicates that the battery is not securely locked in the battery bay. This may allow the battery to slide out inadvertently and cause damage to the battery and anything it impacts.
Parts return
