HP Compaq Elite 8300 Small Form Factor PC - Removing and Replacing the Media Card Reader
This document pertains only to HP Compaq Elite 8300 Small Form Factor PC with the following case design:
This document is provided to assist in removing and replacing the media card reader for the HP Compaq Elite 8300 Small Form Factor PC.
Minimum skill level
The end user requires no hardware-specific training to replace the defective part. The end user should have familiarity with system hardware and software requiring repair.
Parts required
The replacement part number will vary depending on the media card reader that is being replaced. If a part is listed as "Yes" under "Requires Return", then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
Card reader, 22-in-1
636166-001
(Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Media card reader removal instructions
To view a video demonstrating the procedure for removing/replacing the media card reader, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select media card reader from the menu on the upper left hand side of the screen.
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions could result in damage to the product or loss of data.
Step
Procedure
Instruction
1
Remove the access panel.
2
Remove the optical drive.
3
Disconnect the media card reader cable from the system board.
4
Press the green drive release button and slide the media card reader back until it stops.
5
Lift the media card reader up and out of the drive cage.
If the replacement media card reader does not include guide screws, remove and reuse the screws from this drive or use the spare screws provided on the front of the chassis.
Media card reader replacement instructions
Step
Procedure
Instruction
1
Align guide screws on the media card reader with the J-slots in the drive bay and push it down into the drive bay.
2
Press the green drive release button and slide the media card reader forward until it locks into place.
3
Connect the media card reader cable to the system board.
4
Replace the optical drive.
5
Replace the access panel.
Parts return
