HP OFFICEJET PRO X476 AND X576 MFP SERIES - Print tasks (Mac)
Create and use printing presets with Mac
Use printing presets to save the current printer driver settings for reuse.
Create a printing preset
  1. On the File menu, click the Print option.
  2. Select the product from the printer list.
  3. Select the print settings that you want to save for reuse.
  4. In the Presets menu, click the Save As... option, and type a name for the preset.
  5. Click the OK button.
  3. In the Presets menu, select the printing preset.
To use printer-driver default settings, select the standard or Default Settings option.
Print a cover page with Mac
  3. Open the Cover Page menu, and then select where to print the cover page. Click either the Before Document button or the After Document button.
  4. In the Cover Page Type menu, select the message that you want to print on the cover page.
    To print a blank cover page, select the standard option from the Cover Page Type menu.
Print multiple pages on one sheet of paper with Mac
Figure : n-up printing illustration
  2. Select the product from the Printer list.
  3. Open the Layout menu.
  4. From the Pages per Sheet menu, select the number of pages that you want to print on each sheet (1, 2, 4, 6, 9, or 16).
  5. In the Layout Direction area, select the order and placement of the pages on the sheet.
  6. From the Borders menu, select the type of border to print around each page on the sheet.
Print on both sides of the page (duplex printing) with Mac
Use automatic duplex printing
  1. Insert enough paper into one of the trays to accommodate the print job.
  2. On the File menu, click the Print option.
  4. From the Two-Sided menu, select a binding option. This sets the default binding; subsequent duplex jobs can be printed by simply checking the Two-Sided checkbox next to the Copies field.
Set the color options with Mac
If you are using the HP Postscript printer driver for Mac, HP EasyColor technology scans all documents and automatically adjusts all photographic images with the same improved photographic results.
In the following example, the images on the left were created without using the HP EasyColor option. The images on the right show the enhancements that result from using the HP EasyColor option.
Figure : HP EasyColor examples
The HP EasyColor option is enabled by default in the HP Mac Postscript printer driver, so you do not need to make manual color adjustments. To disable the option so you can manually adjust the color settings, use the following procedure.
  2. Select the product from the Printers list.
  3. Open the Color Options menu, and then click the HP EasyColor check box to clear it.
  4. Adjust the RGB Color Settings by selecting a setting from the RGB Color drop-down menu.
