HP 3125 Notebook PC Specifications
Product image
HP 3125 Notebook PC
Product features
Feature
Processors
  • AMD E2-2000 APU (1.75 GHz, 1 MB L2 cache, 1333 MHz) Dual Core 18-W
  • AMD E1-1500 APU (1.48 GHz, 1MB L2 cache, 1066 MHz) Dual Core 18-W
AMD A68M FCH Chipset
Graphics
  • AMD Radeon HD 7340 Graphics (E2-2000 APU)
  • AMD Radeon HD 7310 Graphics (E1-1500 APU)
  • Internal
11.6-inch HD LED BrightView SVA Display (3.6 mm) with 1366 x 768 resolution
  • External
VGA port Support max external resolution 2048 x 1536 @ 60 Hz HDMI 1.4 port supports direct connection to high-definition displays with up to 1920 x 1080 resolution and 7-channel audio with one convenient cable (not included)
Memory
  • Standard
HP 2 GB (DDR3 1,333 MHz) SODIMM
HP 4 GB (DDR3 1,333 MHz) SODIMM Two SODIMM slots
  • Maximum
Supports up to 8 GB maximum
Communications
Integrated Realtek RTL8111E-VL-CG Gigabit Network Connection (10/100/1000* NIC)
Wireless devices
  • Ralink 802.11 b/g/n (1x1) + BT Combo 4.0 HS
Wi-Fi certified Wired Equivalent Privacy (WEP) support up to 128-bit keys Wi-Fi Protected Access (WPA) and WPA2 support 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP Advanced Encryption Standard (AES) support Dual antennas integrated in the display enclosure
  • Intel Centrino Advanced-N 6235 802.11 a/b/g/n 2x2 + BT Combo
Integrated support for 802.11 a, b, g, and n Up to 300 mbps data rate Bluetooth Specification 4.0 High Speed (HS) and 2.1 compliant Works with a wide range of Bluetooth devices
Keyboard
Keyboard is 97% of full size, 101/102-key compatible with isolated inverted-T cursor control keys, both left and right control and alt keys, 12 function keys, and hotkey combinations for audio volume, power conservation, brightness, and other features. US and international key layouts are available.
Pointing device
Touchpad with scroll zone, multi-touch gesture support, on/off button with LED indicator, right and left click zones
Expansion card slots
Secure Digital/MMC slot Supports SD (Secure Digital), MMC (MultiMedia Card), SDHC, SDXC
Storage
  • Internal Storage Device (2.5-inch drives)
320/500 GB 5400 rpm SMART SATA II Hard Drive
  • HP HDD Protection Support (Windows models only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
  • Optical drive
No internal optical; USB external optical drive—HP Mobile USB DVDRW optional
Audio/Visual
HP Beats Audio Dolby Advance Audio codec support Two integrated stereo speakers Integrated digital microphone Standard HD 720p webcam (1280x720)
System standby time
Up to 1 week
Battery
  • Primary Battery
  • 6-cell (55 Whr) high capacity Li-Ion
Battery life
  • 6-cell Primary Battery and Hard Drive
  • Up to 9 hours with Windows 8
Interfaces
  • VGA: One
  • HDMI: One
  • Stereo microphone in: One
  • Stereo headphone/line out: One
  • Power connector: One
  • RJ-45/Ethernet: One
  • USB 2.0: Two
  • USB 3.0: One
Power specifications
Specification
Power supply
External 65-watt smart AC adapter, 3.3-foot (1-meter) power cord included total length including external AC adapter is 8.55 feet (2.59 meter).
Power conservation
Standby ACPI compliance
Power
65W Smart AC adapter
HP MT06 mini battery
HP MT03-06 battery adapter (for 2 and 10 bay chargers)
Max operating power
<65 W
Physical specifications
Specification
Dimensions (H x W x L)
0.83 (at front) x 8.46 x 11.48 in
21.1 (at front) x 214.8 x 291.6 mm
Starting at 1.6 kg (3.52 lb)
Software/OS
Feature
Preinstalled
  • Windows 8 (64-bit)
  • Windows 8 Pro (64-bit)
  • FreeDOS
Supported
Genuine Windows 7 Professional (64 bit) (Web driver support only)
Preinstalled software with windows operating system
  • HP support assistant
  • HP recovery manager (Win 7 support only)
  • HP ePrint
  • HP coolsense
  • Evernote
  • Cyberlink YouCam
  • Norton internet security 2011
Preloaded software
Skype
Configurable software
  • Microsoft office home & business 2010
  • Microsoft office professional 2010
Additional software available from the web
HP softPaq download manager
Environmental specifications
Specification
Operating
Temperature
32° to 95°F (0° to 35° C)
Relative humidity
10% to 90%, noncondensing
Shock
125 G, 2 ms, half-sine
Random vibration
0.75 g
Altitude (unpressurized)
–15.24 to 3,048 m (–50 to 10,000 ft)
Non-operating
Temperature
–4° to 140°F (–20° to 60°C)
Relative humidity
5% to 95%, 101.6°F (38.7° C) maximum wet bulb temperature
Shock
200 G, 2 ms, half-sine
Random vibration
1.50 g
–15.24 to 12,192 m (–50 to 40,000 ft)
Safety certifications
Specification
Industry standard certifications
  • UL: Yes
  • FCC compliance: Yes
  • ENERGY STAR: Yes
  • EPEAT: Silver target
  • ICES: Yes
  • Australia / NZ C-Tick compliance: Yes
  • CCC: Yes
  • Japan VCCI compliance: Yes
  • MIC / KCC: Yes
  • BSMI: Yes
  • CE Marking compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi arabian compliance (ICCP): Yes
  • SABS: Yes
Security
Security Lock Slot
Computrace BIOS support
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
