    Fix Windows 10 Update Issues
    Are you working from home?
HP EliteBook 8470p Notebook PC - Removing and Replacing the Bottom Door
This document pertains only to HP EliteBook 8470p Notebook PC with the following case design:
This document is provided to assist in removing and replacing the bottom door for HP EliteBook 8470p Notebook PC.
Bottom door removal instructions
To view a video demonstrating the procedure for removing/replacing the bottom door, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Bottom door from the menu on the upper left hand side of the screen.
Review the safety considerations before performing the steps listed below by clicking on the following link:
Failure to comply with the precautions when removing and replacing components could result in damage to the product or loss of data.
Step
Procedure
Instruction
1
Remove the battery.
2
On the bottom of the notebook, slide the bottom cover release latch (identified with a bottom cover icon) to the release position to partially eject the bottom cover. Lift the bottom cover out of the accessory bay and remove.
Bottom door replacement instructions
Steps
Procedure
Instruction
1
Align the edges of the bottom cover and place the bottom cover into position.Slide the bottom cover towards the rear of the notebook until it is properly seated and the bottom cover release latch clicks.Slide the bottom cover release latch to the locked position to secure the bottom cover in the accessory bay.
2
Replace the battery.
