Setting Up the Printer Hardware for HP Officejet 7110 Wide Format ePrinter Series
This document explains how to set up the physical parts of the printer. Complete these steps before you install the printer software on your computer.
Setting up the printer
Follow these steps in order.
Step one: Check the contents of the box
Step two: Unpack the printer
  1. Remove the tape and packing material from the front of the printer.
    Figure : Remove the tape and packing material from the front of the printer
    Image: Remove the tape and packing material from the front of the printer.
  2. Turn the printer around, and then remove the tape from the rear of the printer.
    Figure : Remove the tape from the rear of the printer
    Image: Remove the tape from the rear of the printer.
  3. Open the cartridge access door, and then remove any tape or packing material from the cartridge access area.
    Figure : Remove any tape and packing material from the cartridge access area
    Image: Remove any tape and packing material from the cartridge access area.
Step three: Connect the power supply and the power cord, and then turn on the printer
  1. Connect the power supply to the rear of the printer, and then connect the power cord to the electrical supply.
    Figure : Connect the power supply to the rear of the printer, and then connect the power cord to the electrical supply
    Image: Connect the power cord to the printer and an electrical outlet.
  2. Press the Power button to turn on the printer.
    Figure : Turn on the printer
    Image: Turn on the printer.
Step four: Load paper
Follow these steps to load paper in the printer.
  1. Lift the output tray, and then slide the paper guides out as far as possible.
    Figure : Lift the output tray, and then slide the paper guides out
    Image: Lift the output tray, and then slide the paper guides out.
  2. Load the paper in the center of the tray with the short edge first and print-side down.
    Figure : Load the paper print-side down
    Image: Load the paper print-side down.
  3. Push the stack of paper into the tray as far as possible. Make sure that the paper is not higher than the line marking in the tray.
    Do not load paper while the printer is printing. Jams or paper feed issues might occur.
  4. Slide the paper guides in until they touch the edge of the stack.
    Figure : Slide in the paper guides
    Image: Slide in the paper guides.
  5. Lower the output tray, and then pull out the tray extension.
    Figure : Lower the output tray, and then pull out the tray extension
    Image: Lower the output tray, and then pull out the tray extension.
Step five: Install the cartridges
Failure to install the SETUP cartridges that came with the printer causes a cartridge error.
  1. Press the Power button to turn on the printer, if it is not already on.
  2. Open the cartridge access door.
    Image: Open the cartridge access door.
  3. Remove the setup cartridge from its packaging.
  4. Hold the cartridge so that the cartridge contacts are facing toward the printer.
  5. Slide the new cartridge into its slot, and then gently push it forward until it clicks into place.
    Make sure that the colored dot on the cartridge label matches the colored dot on the slot.
    Figure : Install the cartridge into its color-coded slot
    Image: Install the cartridge into its color-coded slot.
  6. Repeat these steps for the other cartridges.
    Figure : Install all the cartridges
    Image: Install all the cartridges.
  7. Close the cartridge access door.
    Figure : Close the cartridge access door
    Image: Close the cartridge access door.
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
Country: Flag Bulgaria
