This document applies to HP Pavilion dv7-7x00 Series Entertainment and HP ENVY dv7-7x00 series notebook computers.
warning:The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer.
caution:This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
note:For best quality on dial-up connections, wait until the video has fully loaded before viewing.
warning:Make sure the computer is disconnected from power before starting.
Step 1
On the bottom of the notebook, slide the battery release latch into the release position to partially eject the battery.
The release latch is identified by a battery icon.
Step 2
Lift the front end of the battery and remove from the computer.
Step 1
Toe the bottom outer edge of the battery into the battery bay.
Step 2
Press down on the inner edge of the battery until it clicks into place.
