HP Designjet T120 and T520 ePrinter Series - Colors are inaccurate
If the colors of your print do not match your expectations, try the following:
  1. Check that the paper type you have loaded corresponds to the paper type selected.
  2. Check that you are printing on the correct side of the paper.
  3. Check that you are using appropriate print-quality settings. For the most accurate colors, select Normal or Best quality.
  4. Print the Print Quality Diagnostic Report. See The Print Quality Diagnostic ReportThe Print Quality Diagnostic Report.
