HP Deskjet, Photosmart 5520 Printers - Printing Photos From a Memory Card
This document is for HP Deskjet Ink Advantage 5525 and HP Photosmart 5520, 5521, 5522, 5524, and 5525 e-All-in-One printers.
Use the memory card slot on the printer to print photos directly from the printer control panel.
Step 1: Load photo paper
Load photo paper into the paper input tray.
  1. Open the paper tray door, and then pull out the paper tray.
  2. Slide the paper width guides to their outermost positions.
    Sliding the paper width guides to their outermost positions
  3. Load a stack of photo paper into the tray with the short edge facing toward the product and the print side down. Push the stack into the tray until it stops.
    Loading photo paper into the tray
  4. Slide the paper width guides in until they rest against the edges of the paper.
    Sliding the paper width guides in
  5. Slide the tray back in until it stops, and then pull open and lift the paper tray extender.
    Opening  the paper tray extender
