HP Compaq L2206tmp 21.5-inch LED Backlit Touch Monitor - Overview
Product description
The future of touch technology is here. Introducing the HP Compaq L2206tmp LED Backlit Touch Monitor – an advanced, 3-touch sensor display with remarkable screen performance, intelligent built-ins and expanded display real-estate with style.
Product features
Feature
Panel
Type
TN (Twisted Nematic) LED backlit LCD
Screen opening (W x H)
47.66 x 26.81 cm (18.76 x 10.56 in)
Aspect ratio
16:9
Viewing angle (typical)
Up to 60° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
160 nits (cd/m2)
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio (typical)1
1,000,000:1
Response rate (typical)1
5 ms (On/Off)
Pixel pitch
0.248 mm
Backlight lamp life (to half brightness)1
30,000 hours minimum
Color gamut
Over 16 million colors (through FRM)
Color gamut (typical)
72%
Anti-glare
Yes
Default color temperature
Standard (6500K)
Tilt range
-5° to + 30°
Swivel range
No
Height adjustable
Yes - from 0 to 13.0 cm (0 to 5.1 in)
Pivot rotation
Yes
Base
Detachable, ships attached
Languages
  • English
  • French
  • German
  • Italian
  • Dutch
  • Spanish
  • Japanese
  • Portuguese
  • Traditional Chinese
  • Simplified Chinese
1. All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Software overview
Features
HP Display Assistant
Software utility that enables theft deterrence and allows monitor adjustment, color calibration, and security/asset management using the Display Data Channel Command Interface (DDC/CI) protocol of the connected PC or workstation.
Pivot Pro Software
Enables a user with a rotating display to easily and instantly switch from landscape to portrait mode, and back.
