HP EliteBook Folio 9470m
Feature
Processor
Intel ULV with vPro support
Memory
Two SODIMMS:
Panel
14.0 inch HD (1366 x 768) Anti-glare SVA
Storage
2.5-inch 7-mm HDD, SSD, mSATA module
Flash cache
Input Devices
Battery
Wireless
Audio / Visual
Ports / Connectors
Security
Feature
Ports
Slots
1 SD
Audio
Integrated camera
720p HD webcam (select models)
Keyboard
Spill-resistant backlit keyboard and drain
Input devices
Feature
1.637 kg (3.61 lb)
Dimensions (W x D x H)
33.8 x 23.1 x 1.89 cm (13.3 x 9.09 x 0.75 in)
Feature
Power supply
45-W Smart AC adapter (models with integrated graphics with dual core)
Battery life
Feature
Software installed
Manageability features
HP 3D DriveGuard (Windows only)
