HP Compaq LE1852ms 18.5-inch LED Backlit Monitor - Specifications
Physical specifications
Feature
Product weight
4.2 kg (9.25 lb) with stand
Dimensions (W x D x H)
44.9 x 4.7 x 27.5 cm (17.67 x 1.85 x 10.82 in)
Dimensions, metric (W x D x H) with stand
44.9 x 19.2 x 33.4 cm (17.67 x 7.55 x 13.14 in)
Panel specifications
Feature
Display size
18.5 in
Aspect ratio
16:9
Display resolution
1366 x 768
Backlighting/#Lamps
TN WLED
Color gamut (Minimum)
72%
BrightView/Antiglare
Non Glare
Brightness (Minimum/Average)
250 nits
Static contrast ratio (Typical)
1000 to 1
View angle (H/V) (Average)
170/160
Response time On/Off (Average/Maximum)
< 5 ms
Number of colors, Panel number of bits
16.7 million
Time to half brightness (Average)
30 k
Brightness uniformity (Minimum)
75%
Electrical specifications
Feature
Battery
Input voltage: 100 to 240 V ac
Power consumption
  • 20 W (Maximum)
  • 18.2 W (Typical)
  • < 0.5 W (Standby)
Environmental specifications
Feature
Operating temperature range
5° to 35°C
Operating humidity range
20% to 80% RH
Safety certifications
Feature
Energy efficiency compliance
  • ENERGY STAR qualified
  • EPEAT Silver
