HP t310 Zero Client - Specifications
Physical specifications
Specification
Dimensions (W x D x H)
15.2 x 13.31 x 4.7 cm (5.98 x 5.24 x 1.85 in)
Weight standard chassis
0.63 kg (1.39 lbs)
Technical specifications
Specification
Power
  • 36-W ac adapter (12 V dc)
  • Worldwide auto-sensing 100 to 240 V ac, 50 to 60 Hz
Languages (MUI)
  • English
  • French
  • German
  • Spanish
  • Traditional Chinese
  • Simplified Chinese
  • Japanese
  • Korean
Environmental specifications
Specification
Temperature range
Operating
10° to 35°C (50° to 104°F)
Non-operating
-20° to 70°C (-4° to 158°F)
Humidity
Condensing
10% to 90%
Specifications are at sea level with altitude derating of 1°C/300 m (1.8°F/1000 ft) to a maximum of 3 km (10,000 ft), with no direct, sustained sunlight. Upper limit may be limited by the type and number of options installed.
Energy consumption
State
115 V ac (60 Hz)
230 V ac (50 Hz)
100 V ac (60 Hz)
Idle state
0.9 W
0.9 W
0.9 W
Off mode
0.6 W
0.6 W
0.6 W
Heat dissipation
State
115 V ac (60 Hz)
230 V ac (50 Hz)
100 V ac (60 Hz)
Idle state
3.07 BTU/hr
3.07 BTU/hr
3.07 BTU/hr
Off mode
2.05 BTU/hr
2.05 BTU/hr
2.05 BTU/hr
Regulatory compliance
Specification
Ergonomics
  • German ZH1/618
  • EN29241-3 approved
Safety
  • UL 60950-1
  • cUL No. 60950-1-07
  • IEC 60950-1
  • EN60950-1
  • EK1-ITB2000
Electro-magnetic compatibility
  • CE (EN 55022; EN55024; EN 61000-3-2; EN61000-3-3)
  • FCC (CFR 47, Part 15)
  • VCCI
