    Windows 11 Upgrade Guide
HP LaserJet Pro MFP - Change print-job settings (Mac OS X)
Priority for changing print-job settings
Changes to print settings are prioritized depending on where the changes are made:
The names of commands and dialog boxes might vary depending on your software program.
  • Page Setup dialog box: Click Page Setup or a similar command on the File menu of the program you are working in to open this dialog box. Settings changed here might override settings changed anywhere else.
  • Print dialog box: Click Print, Print Setup, or a similar command on the File menu of the program you are working in to open this dialog box. Settings changed in the Print dialog box have a lower priority and do not override changes made in the Page Setup dialog box.
  • Default printer driver settings: The default printer driver settings determine the settings used in all print jobs, unless settings are changed in the Page Setup, Print, or Printer Properties dialog boxes.
  • Product control-panel settings: Settings changed at the product control panel have a lower priority than changes made anywhere else.
Change the settings for all print jobs until the software program is closed
  1. Click the File menu, and then click the Print option.
  2. In the Printer menu, select the product.
  3. By default, the print driver displays the Copies & Pages menu. Open the menus drop-down list, and then open a menu for which you want to change the print settings.
  4. For each menu, select the print settings that you want to change.
  5. Change the settings that you want on the various menus.
Change the default settings for all print jobs
  4. For each menu, select the print settings that you want to save for reuse.
  5. In the Presets menu, click the Save As... option, and enter a name for the preset.
  6. Click the OK button.
These settings are saved in the Presets menu. To use the new settings, you must select the saved preset option every time you open a program and print.
Change the product configuration settings
  1. At the computer, open the Apple menu, click the System Preferences item, and then click the Print & Fax icon or the Print & Scan icon.
  2. Select the product in the left side of the window.
  3. Click the Options & Supplies button.
  4. Click the Driver tab.
  5. Configure the installed options.
