Document ID: c03474527
Version: 1
HP Notebook PCs - Windows Password Cannot Be Verified During Preboot
Release date : 30-Aug-2012
Last updated : 30-Aug-2012
DESCRIPTION
The Windows password cannot be verified in a preboot environment. If the password is strictly numeric, this issue does not occur.
This issue occurs under the following conditions:
  • HP ProtectTools Security Manager is enabled on a notebook that does not already have a Windows password.
  • The Windows password is created using the Input Method Editor (IME) built into the operating system. The IME is often used when the operating system language differs from the keyboard language mapping (for example, Traditional Chinese Windows and a US English keyboard).
SCOPE
HP ProBook 4340s Notebook
HP ProBook 4341s Notebook PC
HP ProBook 4440s Notebook PC
HP ProBook 4441s Notebook PC
HP ProBook 4445s Notebook PC
HP ProBook 4540s Notebook PC
HP ProBook 4545s Notebook PC
HP ProBook 4740s Notebook PC
RESOLUTION
This is a known limitation of the Window Input Method Editor (IME), which allows the composition of thousands of characters and symbols (such as Japanese or Chinese words) using a standard keyboard. The IME extends the default keyboard layout within the scope of the operating system to allow for additional methods of language input. However, that extended keyboard layout does not apply in a preboot environment.
To resolve this issue, press the Shift key at the preboot login screen, then enter the password.
If the Shift key is not pressed, then the password entry fails the first two times, showing the same password screen both times.
Figure 1: Initial password entry screen (Simplified Chinese)
Figure 2: Password entry (appears two times if no Shift key used)
On the third attempt, the on-screen keyboard appears, at which time it may be correctly entered.
Hardware platforms affected : HP ProBook 4340s Notebook PC, HP ProBook 4341s Notebook PC, HP ProBook 4440s Notebook PC, HP ProBook 4445s Notebook PC, HP ProBook 4540s Notebook PC, HP ProBook 4545s Notebook PC, HP ProBook 4740s Notebook PC
Support Communication Cross Reference ID : IA03474118
