HP Scitex FB500/FB700/FB950/FB910/HP Designjet H-Series/ColorSpan Legacy UV/Solvent - Installation Note for Main Carriage Encoder Strip
HP spare part supplies a replacement kit for the main carriage encoder strip found on all of the printer models named above. The documentation included in that kit omits a key detail relevant to all models, and omits documentation for some models entirely. This document supplies the necessary information.
Details
Installation note for all printers:
The rolled encoder strip has two sides, top and bottom. The bottom side is the film emulsion. The top side has no emulsion and has a shiny appearance compared to the duller emulsion side.
When installed, the shiny side (top) should be facing up, so that the emulsion side (bottom) is more protected from falling airborne dust and aerosol ink particles.
Installation note for HP Scitex FB500 and FB700:
The Service Manual (HP document CQ114-90035) omits specific instructions for replacement using this rolled encoder strip and foam FRM. The instruction set included in this kit for the HP Scitex FB910 (HP document CH971-76386, “Installation Instructions for Carriage Drive Assemblies for FB910)” should be consulted for details concerning the removal of the old encoder strip and tape from the aluminum bar, and the installation of the new strip and tape onto the aluminum bar.
Installation note for HP Scitex FB950:
Documentation for this printer is not included in this FRM. The instruction set included in this kit for the HP Scitex FB910 (HP document CH971-76386, “Installation Instructions for Carriage Drive Assemblies for FB910)” should be consulted for details concerning the removal of the old encoder strip and tape from the aluminum bar, and the installation of the new strip and tape onto the aluminum bar.
If additional information related to the general removal and installation of the strip assembly is required, HP document CH971-76446, “Installation Instructions for Carriage Drive Assemblies for FB950”, should be consulted.
Installation note for HP Designjet H-Series:
If additional information related to the general removal and installation of the strip assembly is required, HP document CH971-76412, “Installation Instructions for Carriage Drive Assemblies for Designjet H-Series”, should be consulted.
