Adding or Replacing an MXM Graphics Card in HP ENVY 23-1000 All-in-On Series Desktop PCs
This document applies to HP ENVY All-in-One 23-1000 desktop computers.
HP ENVY 23-1000 All-in-One desktop computers
Before you begin
  • Have a Phillips head screwdriver ready.
  • Turn off the computer, disconnect the Ethernet or modem cable, and disconnect the power cord.
  • Transfer the computer to a clean, flat, stable work surface over a noncarpeted floor. HP recommends that you put down a blanket, towel, or other soft cloth to protect the screen from scratches or other damage.
  • Use an antistatic wrist strap and a conductive foam pad when working on the computer. Electrostatic discharge (ESD) can damage your processor, disk drives, expansion boards and other components. HP strongly recommends the use of the wrist strap and conductive foam pads to reduce the risk of damage to your computer.
  • Remove a component from its protective packaging only when you are ready to install it.
Video overview
Removing the MXM graphics card
Use the following steps to remove the graphics card:
Step 1
To remove the MXM graphics card, you must first remove the rear cover, the USB dongle, the motherboard EMI shield, the CPU thermal module, and the MXM thermal module.
For instructions to remove the rear cover, see the HP support document, Removing and Replacing the Rear Cover.
Removing the rear cover
Step 2
Pull out the USB dongle if it is present in your computer.
Removing the dongle
Step 3
To remove the EMI shield, remove the five screws securing the motherboard EMI shield to the computer.
The EMI shield screw locations are marked with a stencil of an arrow that does not have a circle inside.
Removing  the EMI shield screws
EMI shield screw
Step 4
Carefully tip the shield up and pull it off the computer.
Removing the shield
Step 5
Next, loosen the four screws securing the thermal module to the CPU.
Loosening the four screws
Step 6
Detach the screw near the radiator end of the thermal module.
Detaching the radiator screw
Step 7
Carefully lift the CPU thermal module out of the computer.
Removing the CPU thermal module
Step 8
Loosen the four screws securing the MXM thermal module to the MXM graphics card.
Loosening the four screws on the MXM thermal module
Step 9
Detach the screw near the radiator end of the MXM thermal module.
Step 10
Carefully lift the MXM thermal module out of the computer.
Lifting the MXM thermal module out
Step 11
Detach the two small screws on the graphics card...
Detaching the two screws
... so that the card pops up.
Card pops up
Step 12
Pull out the card.
Pulling out the card
Replacing the MXM graphics card
Use these steps to replace the graphics card:
Step 1
To replace the graphics card, align the card into its slot at a 45 degree angle.
Aligning and inserting the card at a 45 degree angle
Step 2
Push the card down into the slot and replace the two screws. Hold the card down while replacing the first of the two screws.
Step 3
Before replacing the MXM thermal module assembly, first clean the old thermal solution from the MXM graphics card by applying a cleaning agent and then wiping it clean.
Applying cleaning solution to  the graphics card
Cleaning the graphics card
Step 4
Repeat the cleaning procedure on the thermal module.
Cleaning the MXM thermal module
Step 5
Apply new thermal grease or thermal pad to the MXM graphics card.
Applying new thermal pad
Step 6
Carefully align the MXM thermal module back onto the computer.
Replacing the MXM thermal module
Step 7
Tighten the screws over the MXM graphics card.
Tightening the screws on the thermal module
Step 8
Replace the screw near the radiator.
Replacing the screw near the radiator
Step 9
Before replacing the CPU thermal module assembly, first clean the thermal solution from the CPU by applying a cleaning agent and then wiping it clean.
Applying the cleaning solution
Wiping the CPU clean
Step 10
Wiping the module clean
Step 11
Apply new thermal grease or thermal pad to the CPU.
Applying the thermal grease
Step 12
Carefully align the thermal module back onto the computer, sliding the radiator between the MXM thermal module and the system fan.
Aligning the CPU thermal module on the computer
Step 13
Tighten the screws for the CPU thermal module.
Tightening the four screws
Step 14
Step 15
To replace the motherboard EMI shield, find the small slot on the side of the shield...
Finding the locating slot on the shield
...and then find the alignment tab on the frame.
Finding the alignment tab on the frame
Step 16
Find the two small holes on the bottom of the EMI shield...
Finding the two holes on the shield
...and then find the two alignment tabs on the frame.
Finding the two alignment tabs
Step 17
To replace the motherboard EMI shield, align the slot on the shield over its alignment tab, and carefully swing and press the shield into place.
Replacing the shield
Step 18
Make sure the bottom holes on the shield are resting flat around the alignment tabs.
Checking the alignment of the holes and tabs
Step 19
Replace the five screws for the motherboard shield. Each screw location is marked with a stencil of an arrow without a circle inside.
Replacing the screws that secure the shield to the frame
Step 20
Replace the USB dongle.
Replacing the USB dongle
Step 21
Replace the rear cover.
For instructions to replace the rear cover, see the HP support document, Removing and Replacing the Rear Cover.
Replacing the back cover
