    Windows 11 Upgrade Guide
HP Indigo Digital Press - IPTech RIP Cropping Final Image
When ripping files to an IPTECH based RIP engine, either on an NT or XP platform, the resultant print file is cropped to the size of the sheet width.
This is either due to:
  1. A fault with the PPD file in use in the origination package or the RIP setting on the Press.
  2. LAN setting for JLYT processing as defined in the Personalization Queue.
Solution
  1. In QuarkExpress:
    • Run the installer package for the application version in use.
    • Select the option to Custom install and install only the PPD files.
    This is particularly relevant if using a custom location for the PPD drivers, or on an Macintosh system the OS was re-installed or upgraded.
  2. If incorrect LAN setting:
    • Open the RIP GUI.
    • Click the Left hand Button.
    • Select the Personalization Setup.
    • In the Page Tab click the pull-down menu for Oversized Jobs.
    • Set this to Permit oversized jobs.
    • Re-process /Re-submit the original JLYT file to the RIP via the LAN folder.
