HP EliteBook 8470w Mobile Workstation - Specifications
Physical specifications
Specification
  • Starting at 2.25 kg (4.96 lb) with SSD and weight saver (no optical drive)
  • Starting at 2.39 kg (5.27 lb) with SSD and DVD-ROM drive
Dimensions (W x D x H)1
31.8 x 338 x 231.3 mm (1.25 x 13.31 x 9.11 in) (at front)
1: Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, hard drive, 1GB memory, and no optical drive. Weight varies by configuration and components.
Electrical specifications
Specification
Power supply
  • External 90-W HP non-Smart AC adapter
  • Power cord included is 1.8 m (6 ft)
  • Total length including external AC adapter is 3.66 m (12 ft).
  • HP Fast Charge
Primary battery
  • HP 9-cell Lithium-Ion Battery (100 Whr)
  • HP 6-cell Lithium-Ion Battery (62 Whr)
  • HP long life 6-cell Lithium-Ion Battery (55 Whr)
Secondary battery
  • HP BB09 Ultra Extended Life Notebook Battery (9-cell/100 Whr)
  • HP ST09 Extended Life Notebook Battery (9-cell/73 Whr)
System standby time
Up to 30 days
Stand-alone power requirements (AC power)
Nominal operating voltage
18.5 V
Max operating power
<65 W
Average operating power
  • Integrated graphics:
    • Windows 7 (32-bit): 9.14 W
    • Windows 7 (64-bit): 9.07 W
  • Discrete graphics:
    • Windows 7 (32-bit): 13.62 W
    • Windows 7 (64-bit): 13.31 W
Environmental specifications
Specification
Temperature
  • Operating:
    • 0° to 35°C (32° to 95°F) (not writing optical)
    • 5° to 35°C (41° to 95°F) (writing optical)
  • Non-operating: -20° to 60°C (-4° to 140°F)
Relative humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
  • Operating: 40 G, 2 ms, half-sine
  • Non-operating: 200 G, 2 ms, half-sine
Random vibration
  • Operating: 0.75 g
  • Non-operating: 1.50 g
Altitude (unpressurized)
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Displays
14.0-inch LED HD (1366 x 768) anti-glare
Specification
Dimensions (W x H)
32.4 x 19.2 cm (12.74 x 7.56 in)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
400:1 (typical)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.227 mm
  • Format: 1366 x 768
  • Configuration: RGB stripe
Backlight
LED
PPI
112
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum) or
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
14.0-inch LED HD+ (1600 x 900) anti-glare
Specification
Dimensions (W x H)
32.4 cm x 19.2 cm (12.74 x 7.56 in)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (typical)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.1935 mm
  • Format: 1600 x 900
Backlight
LED
PPI
131
Viewing angle
Storage and drives
Internal storage
Drive Weight
Capacity
Height
Width
Interface
Transfer Rate
Seek Time
Performance
Rotational Speed
Logical Blocks
Operating Temperature
Features
750GB 7200 rpm SATA hard drive
101 g (0.22 lb)
750GB
9.5 mm (0.37 in)
70 mm (2.75 in)
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Synchronous (maximum) 300 MB/s (drive capability)
  • Single track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
7200 rpm
1,465,149,168
0° to 60°C (32° to 140°F) (case temp)
ATA security
500GB 7200 rpm SMART SATA II Self encrypting drive
115 g (0.25 lbs)
500GB
9.5 mm (0.37 in)
70 mm (2.75 in)
  • Average: 11 ms
  • Maximum: 22 ms
7200 rpm
976,773,168
ATA security
320GB 7200 rpm SATA hard drive
115 g (0.25 lbs)
320GB
9.5 mm (0.37 in)or on some models 7 mm (0.28 in)
70 mm (2.75 in)
  • Average: 11 ms
  • Maximum: 22 ms
7200 rpm
625,142,448
ATA security
SATA 6 Gb/s 256GB, 2.5-inch SATA SED Solid State Drive
73 g
256GB
7 mm (0.276 in)
70 mm (2.75 in)
SATA 3 (6 Gb/s)
  • Maximun sequential read: Up to 460 MB/s
  • Maximum sequential write: Up to 260 MB/s
500,118,192
0° to 70°C (32° to 158°F) (case temp)
  • ATA security
  • ATA-8 compliant
  • SATA 3.0
  • DIPM
  • TRIM
SATA 6 Gb/s 180GB, 2.5-inch Solid State Drive
78 g
180GB
7 mm (0.276 in)
70 mm (2.75 in)
SATA 3 (6 Gb/s)
  • Maximun sequential read: Up to 550 MB/s
  • Maximum sequential write: Up to 520 MB/s
351,651,888
  • ATA security
  • ATA-8 compliant
  • SATA 3.0
  • DIPM
  • TRIM
SATA 6 Gb/s 128GB, 2.5-inch Solid State Drive
73 g
128GB
7 mm (0.276 in)
70 mm (2.75 in)
SATA 3 (6 Gb/s)
  • Maximun sequential read: Up to 415 MB/s
  • Maximum sequential write: Up to 175 MB/s
250,069,680
  • ATA security
  • ATA-8 compliant
  • SATA 3.0
  • DIPM
  • TRIM
Optical drives
Drive
Access Times
Max Data Transfer Rate
Transfer Mode
Interface
Supported Media (read)
Supported Media (write)
Max Media Capacity (read)
Max Media Capacity (write)
Transport
DVD-ROM Drive
Random:
  • <140 ms CD (typical)
  • <160 ms DVD (typical)
  • 24X CD-ROM
  • 8X-DVD
UDMA Mode 5
Gen 1 SATA
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
None
8.5GB
Tray loading
DVD+/-RW SuperMulti DL Drive
Random:
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 6X - DVD+R dual layer
  • 6X - DVD-R dual layer
  • 5X DVD-RAM
UDMA Mode 5
Gen 1 SATA
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
8.5GB
8.5GB
Tray loading
Blu-ray ROM DVD+/-RW SuperMulti DL Drive
Random:
  • <190 ms CD-ROM (typical)
  • <180 ms DVD-ROM (typical)
  • <230 ms BD-ROM (typical)
  • 24X CD-ROM
  • 8X DVD-ROM
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 5X DVD-RAM
  • 6X BD-ROM
UDMA Mode 5
Gen 1 SATA
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, BD-ROM, BD-R, BD-RE
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-RAM
50GB
8.5GB
Tray loading
Blu-ray R/RE DVD+/-RW SuperMulti DL Drive
Random:
  • 24X CD-ROM
  • 8X DVD-ROM
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD+R dual layer
  • 6X DVD-R dual layer
  • 5X DVD-RAM
  • 6X BD-ROM
  • 6X BD-R
  • 2X BD-RE
UDMA Mode 5
Gen 1 SATA
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW. DVD-RAM, BD-ROM, BD-R, BD-RE
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-RAM, BD-R, BD-RE
50GB
50GB
Tray loading
Network/Communications specifications
Intel 82579LM Gigabit Network Connection
Feature
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023. Clauses 40)
  • Auto-Negotiation (Automatic speed selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mb/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE (Energy Efficient Ethernet)
  • Jumbo Frame 9K
  • Auto MDI/MDIX Crossover cable detection
Power
ACPI compliant - multiple power modes
Management
Energy detect low power mode (Green Ethernet)
Performance
TCP/IP/UDP checksum offload (configurable)
Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Protocol Offload (ARP & NS)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
  • MACSec Offload (802.3ae)
  • Intel vPro
  • iSCSI Boot
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame)
  • Wake-on-LAN from Off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface1
PCI Express 1.1 x 1 to fully support ASPM L0s/L1 and CLKREQ.
NIC device driver name
Intel 82579LM/82579V Ethernet Network Connection
1: Intel 82579 PCIe interface is not PCIe compliant. It operates at half of PCIe specification V1.1 (2.5 GT/S) speed.
V.92 56K Data/Fax Modem
Feature
Form factor
MDC 1.5 Daughtercard
Power management support
APM Revision 1.2, ACPI
Approvals/Certifications
UL, CSA, NEMKO, CCIB, Industry Canada, FCC Part 68, CTR21, FCC Part 15 Class B, Canadian ICES-003 Class B, C.I.S.P.R.22, Australian ACA, CE Mark, Other Countries
Data mode capabilities
  • V.92 data
  • V.8bis
  • V.80
  • V44, V.42bis, MNP5 (Compression)
  • V.42 (LAPM, MNP2-4) (Error Correction)
  • Optional symbol rates:
    • 2800, 3429
    • Asymmetric Symbol rates
  • Synchronous primary channel data signaling rates:
    • 3600, 31200
    • Automatic rate re-negotiation
    • V.34
    • V.32bis
    • V.32
    • V.23
    • V.22bis
    • V.22
    • V.21
    • Bell 212A
    • Bell 103J
Fax mode capabilities
  • TIA/EIA-578-B (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
  • T.31
Command set
  • V.250 (Partial)
  • TIA-602
  • Identification: +GMI, +GMM, +GMR
  • Port control: +IPR, +ICF, +IFC, +ILRR
  • Modulation: +MS, +MR, +MA
  • Error control: +ES, +ER, +EB, +ESR, +ETBM
  • Data compression: +DS, +DR
  • V.251
HP un2430 EV-DO/HSPA Mobile Broadband Module
Features
Technology/operating bands
  • GSM/GPRS/EDGE: 850 MHz (Cell), 900 MHz (EGSM), 1800 MHz(DCS), 1900 MHz (PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), AWS (UTRA FDD Band IV), 900 MHz(UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • 1xEVDO/1xRTT with receive diversity: 850 MHz (Band Class0-Cell), 1900 MHz (Band Class1-PCS)
Wireless protocol standards
  • GSM/GPRS/EDGE: Class A, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9.
  • UMTS/WCDMA: Release 99 and Release 6
  • CDMA: 1xEVDO Release 0 and Release A, IS-95A, IS-95B, IS-856, IS-2000
Wireless parametric standards
Meets or exceeds TIA/EIA IS-98-D
Maximum data rates
  • UMTS (HSPA) - 14.4 Mb/s (Download), 5.76 Mb/s (Upload)
  • CDMA (EVDO Release A) - 3.1 Mb/s (Download), 1.8 Mb/s (Upload)
GPS
  • Standalone GPS enabled
  • gpsOneXTRATM
GPS bands
L1 - 1575.42 MHz
Maximum output power
  • GSM/GPRS/EDGE: 32 dBm (+/-1)
  • WCDMA: 24 dBm (+0.7/-2.3)
  • CDMA: 24 dBm (+0.7/-2)
Maximum power consumption
2750 mA (peak); 1100 mA (average)
Power consumption, Idle not connected
20 mA
Power management
  • USB selective suspend
  • Integrated notebook wireless button
Antenna type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express MiniCard, USB 2.0 interface
11.5 g
Dimensions (Length x Width x Thickness)
51 x 30 x 5 mm (2.01 x 1.18 x 0.18 in)
Voltage, Operating
3.3 V +/- 10%
Temperature, Operating (from TIA/EIA/IS-98-D)
  • -30° to 70°C (-22° to 158°F) (full RF performance)
  • -30° to 75°C (-22° to 167°F) (reduced RF performance)
Temperature, Non-operating, 96 hours (from MIL-STD 202 Method 108)
-40° to 85°C (-40° to 185°F)
Humidity, Non-operating
95% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
Configuration utilities
HP connection manager
LED activity
  • LED Off: Radio Off
  • Solid LED On: Radio On
HP hs2350 HSPA+ Mobile Broadband Module
Feature
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), AWS (UTRA FDD Band IV), 900 MHz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • UMTS/WCDMA: Release 99 and Release 7
  • Advanced Receiver Type 3i
Complies with 3GPP specifications
Maximum data rates
UMTS (HSPA) - 21 Mb/s (Download), 5.76 Mb/s (Upload)
GPS
Standalone, A-GPS (Internet- and Network assisted)
GPS bands
1575.42 MHz (±1.023 MHz)
  • GSM/EDGE
  • GSM850 & GSM900 bands
  •  GPRS: +33 dBm ± 2 dBm (class 4)
  • EGPRS: +27 dBm ± 3 dBm (class E2)
  • DCS1800 & PCS1900 bands
  • GPRS: +30 dBm ± 2 dBm (class 1)
  • EGPRS: +26 dBm +4 / -3 dBm (class E2)
  • UMTS
  • UTRA FDD Bands
  • +24 dBm +4/-3 dBm (class 3)
2000 mA (peak); 600 mA (average)
Power consumption, sleep mode
5 mA
Power management
Antenna type
Form factor
<12 g
Voltage, Operating
3.3 V+/- 9%
  • -10° to 65°C (14° to 149°F) (full RF performance)
  • -10° to 75°C (14° to 167°F) (reduced RF performance)
-30° to 85°C (-22° to 185°F)
85% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
HP Connection Manager
LED activity
HP lt2522 LTE/EV-DO Mobile Broadband Module
Feature
  • CDMA/1xRTT/EvDO: 800 MHz (Cell), 1900 MHz (PCS)
  • GSM/GPRS/EDGE: 850 MHz (Cell), 900 MHz (EGSM), 1800 MHz (DCS), 1900 MHz (PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), 900 MHz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • LTE: 700 MHz (Verizon, Band XIII)
  • LTE: Power Class III as per 3GPP TS 36.101
Mobile operator
Verizon (US only)
Complies with 3GPP specifications Release 8 for LTE
Maximum data rates
  • EvDO (Revision A) - 3.1 Mb/s (Download), 1.8 Mb/s (Upload)
  • WCDMA (DC-HSPA+) - 42 Mb/s (Download)
  • LTE (Category 3) - 100 Mb/s (Download), 50 Mb/s (Upload)
GPS
Standalone, Assisted, XTRA
GPS bands
1575.42 MHz (± 1.023 MHz)
  • LTE: +23 dBm (+2.7 dBm/-1.7 dBm)
  • 1xRTT/EvDO: +24 dBm (+0.5 dBm/-1.5 dBm)
2700 mA (peak)
10 mA
Power management
Antenna type
Form factor
<10 g
51 x 30 x 4.5 mm (2.01 x 1.18 x 0.18 in)
Voltage, Operating
3.3 V+/- 9%
-20° to 65°C (-4° to 149°F)
-40° to 85°C (14° to 185°F) (reduced RF performance)
LED activity
HP lt2523 LTE/HSPA+ Mobile Broadband Module
Feature
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), 900MHz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • LTE: AWS (Band IV) 700 MHz (AT&T, Band XVII)
Mobile operator
AT&T (US only)
Maximum data rates
GPS
GPS bands
2700 mA (peak)
10 mA
Power management
Antenna type
Form factor
<10 g
Voltage, Operating
3.3 V+/- 9%
LED activity
Intel Centrino Advanced-N 6205 (2 x 2)
Feature
Wireless LAN standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant with Microsoft Windows, Windows Vista and XP
Frequency band
2.4 GHz and 5 GHz
Antenna structure
2 transmit; 2 receive (2 x 2)
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 66 possible data rates, ranging from 6 Mb/s to 300 Mb/s, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • Authentication: WPA and WPA2, 802.1x (EAP_TLS, TTLS, PEAP, LEAP, EAP-FAST)
  • Authentication Protocols: PAP, CHAP, TLS, GTC, MS-CHAP, MS-CHAPv2
  • Encryption: 64 and 128-bit WEP, AES-CCMP, CKIP, TKIP
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows Vista and XP only.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between 2.4GHz band Access Points
Output power (for CCK and OFDM)
17 dBm max
Power consumption
  • Transmit: 2.3 W (max, with two spatial streams)
  • Receive: 1 W (max with two spatial streams)
  • Idle mode: 35 mW (average)
  • Radio Off: 20 mW (max)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity
  • 54 Mb/s: -76 dBm
  • 6 Mb/s: -92 dBm
Antenna connections
2 U.FL type connectors, 50 ohm nominal impedance
Form factor
<3.4 g (0.0075 lb)
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
Voltage, Operating
3.3 V+/- 9%
Temperature
  • Operating: 0° to 80°C (32° to 176°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
  • Non-operating: 5% to 90% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
Intel Centrino Ultimate-N 6300
Feature
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
Frequency band
2.4 GHz and 5 GHz
Antenna structure
3 transmit; 3 receive (3 x 3)
Data rates
Modulation
Security
Sub-channels
Roaming
17 dBm max
Power consumption
  • Transmit: 1.4 W (max, with two spatial streams)
  • Receive: 1.3 W (max with two spatial streams)
  • Idle mode: 30 mW (average)
Power management
  • 54 Mb/s: -76 dBm
  • 6 Mb/s: -92 dBm
Antenna connections
Form factor
<3.4 g (0.0075 lb)
Dimensions
Voltage, Operating
3.3 V+/- 9%
Temperature
Humidity
Altitude
LED activity
Broadcom 43224AGN 802.11a/b/g/n (2 x 2)
Feature
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
Frequency band
2.4 GHz and 5 GHz
Antenna structure
Data rates
Frequency support
  • 20 MHz: 2.4 GHz and 5 GHz bands
  • 40 MHz: 2.4 GHz and 5 GHz bands
Modulation
  • BPSK, QPSK, 16QAM, 64QAM, 256QAM, DBPSK,DQPSK and CCK
Security
  • Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST.
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows 7, Vista and XP only.
Sub-channels
Roaming
IEEE 802.11 compliant roaming between 2.4 GHz band Access Points
Output power (for CCK)
17 dBm, nominal
Output power (for OFDM)
15 dBm, nominal
Power consumption
  • Idle associated: 250 mW
  • Idle unassociated: 150 mW
  • Transmit/Receive 20 MHz channel: 2.0 W (max)
  • Transmit/Receive 40 MHz channel: 2.0 W (max)
Power management
  • 270 Mb/s: -68 dBm
  • 54 Mb/s: -75 dBm
  • 11 Mb/s: -88 dBm
  • 1 Mb/s: -96 dBm
Antenna connections
High efficiency dual band antenna with spatial diversity, mounted in the display enclosure
Form factor
6 g (0.013 lb)
Dimensions
4.75 x 26.65 x 30.0 mm (0.19 x 1.05 x 1.18 in)
Voltage, Operating
3.3 V+/- 10%
Temperature
  • Operating: -10° to 70°C (14° to 158°F)
  • Non-operating: -40° to 212°C (-40° to 100°F)
Humidity
  • Operating: 0% to 95% (non-condensing)
  • Non-operating: 0% to 95% (non-condensing)
Altitude
LED activity
HP Integrated Module with Bluetooth 4.0+EDR Wireless Technology
Feature
Bluetooth specification
4.0+EDR Compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous Connection Oriented links up to 3, 64 kb/s, voice channels
  • Asynchronous Connection Less links 2178.1 kb/s/177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1 % raw bit error rate
Security
Full support of Bluetooth Security Provisions
Power consumption
  • Peak (Tx): 264 mW
  • Peak (Rx): 231 mW
  • Sleep: <1 mW
Power management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Antenna
Internally integrated within module
Range
Upto 10 m (33 ft)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software supported
  • Microsoft Windows Bluetooth Software
  • Broadcom Bluetooth for Windows
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Temperature
Humidity
  • Operating: 0% to 90%
Altitude
  • Operating: 4,572 m (15,000 ft)
  • Non-operating: 12,192 m (40,000 ft)
Bluetooth profiles supported
  • Serial Port Profile (SPP)
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
Security
HP Fingerprint Sensor
Feature
Mobile voltage operation
3.0 to 3.6 V Single Supply
Operating temperature
0° - 70°C (32° - 158°F)
Current consumption @ 3.3 V
  • Less than 70 mA peak imaging and scrolling
  • Less than 25 mA hardware finger detection
  • Advanced Power Management
High-rate image capture
Up to 240 image frames/sec
ESD resistance
IEC 61000-4-2 Level 4 (±15 KV)
Detection matrix
  • 192 x 16 Pixels
  • 9.7 x 0.81 mm
  • 500 ppi High-Resolution Images
Audio/Multimedia
Feature
Implementation
IDT 92HD80 High Definition CODEC
Function key volume controls
Volume up, volume down, and mute
Mute button
Volume mute button with LED indicator
Full duplex
Yes
Microphone In
Stereo
Headphone/Line Out
Stereo
Integrated Microphone
Yes, dual digital microphone array
Audio output quality
Frequency response
20 Hz to 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling rate(s)
8 kHz to 48 kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Internal stereo speaker
Power rating
2 W
Impedance
4 ohms
Power specifications
HP 90-W Smart AC adapter
Feature
Dimensions
12.7 x 5.0 x 2.9 cm (5.00 x 1.97 x 1.1 in)
370 g (0.82 lb)
Input
  • 100 to 240 V ac
  • Input efficiency: 87% min at 115 V ac
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.5 A at 90 V ac, 0.75 A at 180 V ac PFC Version
Output
  • Output power: 90 W
  • DC Output Voltage: 19.0 V
  • Hold-up time: 5 ms at 115 V ac input
  • Output current limit: <11 A, Over voltage protection- 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating temperature : 0° to 40°C (32° to 104°F)
  • Non-operating temperature (storage): -20° to 65°C (-4° to 149°F)
  • Altitude: 0 to 3,048 m (0 to 10,000 ft)
  • Humidity: 20% to 80%
  • Storage humidity: 10% to 90%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C (77°F) ambient condition.
Battery specifications
Battery
Dimensions (H x W x L)
Weight (max)
Cells/Type
Energy
Temperature
Battery Re-Charge Time
Fuel Gauge LED
Optional Travel Battery Available
HP 9-cell (100 Whr) Lithium-Ion Primary battery
2 x 6.6 x 20.5 cm (0.8 x 2.4 x 8.1 in)
0.488 kg (1.1 lb)
Lithium-Ion
  • Voltage 11.25 V
  • Amp-hour capacity 8.85 Ahr
  • Watt-hour capacity 100 Whr
  • Operating (Charging) 0° to 45°C (32° to 113°F)
  • Operating (Discharging) -10° to 50°C (14° to 122°F)
  • Non-operating -20° to 50°C (-4° to 122°F)
  • System in Off or Standby Mode: 3.5 to 5 hours
  • System On: 4 to 7 hours
No
1 year
Yes
6-Cell (62 Whr) Lithium-Ion battery
2.0 x 5.1 x 21.1 cm (0.8 x 2.0 x 8.3 in)
0.325 kg (0.72 lb)
6-cell Lithium-Ion
Watt-hour capacity: 62 Whr
  • Operating (Discharging) -10° to 60°C (14° to 140°F)
  • Non-operating -20° to 60°C (-4° to 140°F)
  • System in Off or Standby Mode: 2.5 hours
  • System On: 3 to 5 hours (depending on system power consumption
HP 6-cell (55 Whr) Long Life Battery
2.0 x 4.7 x 20.5 cm(0.8 x 1.8 x 8.0 in )
0.323 kg (0.72 lb)
Lithium-Ion
  • Voltage 10.8 V
  • Amp-hour capacity 5.1 Ahr
  • Watt-hour capacity 55 Whr
No
3 years
Yes
Optional HP BB09 Ultra Extended Life Notebook Battery (secondary battery)
3 x 15 x 2 9 cm (1.2 x 5.9 x 11.4 in)
0.682 kg (1.5 lb)
Lithium-Ion
  • Voltage 11.25 V
  • System On: 4 to 7 hours (depending on system power consumption
Yes
1 year
No
Optional HP ST09 Extended Life Notebook Battery ("Travel Battery") (secondary battery)
3 x 15.5 x 30.5 cm (1.2 x 6.1 x 12 in)
0.550 kg (1.2 lb)
Lithium-Ion Polymer
  • Voltage 11.1 V
  • Amp-hour capacity 6.6 Ahr
  • Watt-hour capacity 73 Whr
Yes
1 year
Yes
System configuration
Energy Consumption
115 V ac
230 V ac
100 V ac
Normal operation
8.6 W
9.27 W
8.32 W
 Sleep (Energy star low)
0.6 W
0.7 W
0.6 W
Off
0.61 W
0.68 W
0.58 W
Heat dissipation
Normal operation
29.4 BTU/hr
31.7 BTU/hr
28.4 BTU/hr
Sleep
2 BTU/hr
2.3 BTU/hr
2 BTU/hr
Off
2 BTU/hr
2.3 BTU/hr
2 BTU/hr
Declared Noise Emissions (in accordance with ISO 7779 and ISO 9296)
System fan Off
Sound power (LWAd, bels)
Sound pressure (LpAm, decibels)
Idle
3
26
Fixed disk
3.4
26
Safety certifications
Specification
Eco-Label Certifications
US Energy Star
IT ECO declaration
EPEAT Gold where HP registers commercial desktop products
Country: Flag Bulgaria
