    We are upgrading our website
HP EliteBook 8570w Mobile Workstation - Overview
Product description
HP EliteBook 8570w Mobile Workstation has FORGE Industrial Design Intel’s latest chipset and mobile processors. It is designed to meet the military standard Mil-Std-810G for vibration, dust, altitude, and high temperature operation with workstation-caliber discrete graphics: AMD FirePro M4000 (1GB GDDR5), NVIDIA Quadro K1000M (2GB DDR3), NVIDIA Quadro K2000M (2GB DDR3). Intel Core i5 with vPro and Core i7 with vPro technology is a selectable feature that is available on units configured with select processors.
Product features
Feature
Processor
  • 3rd Generation Intel Core i7-3820QM (2.7 GHz, 8MB L3 cache, 4 cores)1
    Up to 3.70 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i7-3720QM (2.6 GHz, 6MB L3 cache, 4 cores)1
    Up to 3.60 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i7-3610QM (2.3 GHz, 6MB L3 cache, 4 cores) (no vPro support)1
    Up to 3.30 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i7-3520M (2.9 GHz, 4MB L3 cache, 2 cores)1
  • 3rd Generation Intel Core i5-3360M (2.8 GHz, 3MB L3 cache, 2 cores)1
    Up to 3.50 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3320M (2.6 GHz, 3MB L3 cache, 2 cores)1
Mobile Intel QM77 Express
Graphics
  • AMD FirePro M4000 with 1GB dedicated GDDR5 video memory
    Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.1/4.1+capable
  • AMD Eyefinity Technology supports up to five independent displays2
    When using an HP Advanced Docking station (sold separately)
  • NVIDIA Quadro K1000M with 2GB dedicated DDR3 video memory
    Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.2 capable
  • NVIDIA Quadro K2000M with 2GB dedicated DDR3 video memory
Display3
Internal:
  • 15.6 in diagonal LED-backlit HD+ WVA anti-glare (1600 x 900)
  • 15.6 in diagonal LED-backlit FHD WVA anti-glare (1920 x 1080)
  • 15.6 in diagonal LED-backlit FHD UWVA anti-glare DreamColor (1920 x 1080)
  • HP privacy filter support
External:
Up to 32-bit per pixel color depth
DisplayPort:
Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
VGA:
Port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
DVI-D (single link):
Video signal available through DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Flash Cache module
Optional 24GB mSATA Flash cache module support for Intel Smart Response Technology. (Available only with standard non-SED hard drive).
Storage and drives4
Primary storage bay:
Hard drives:
  • 320/500/750GB 7200 rpm SMART SATA II
  • 500GB 7200 rpm SMART SATA II Self Encrypting Drive
  • HP 3D DriveGuard (Windows only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Solid State Drive (SSD):
  • 128/180GB SATA 6 Gb/s
  • 256GB SATA 6 Gb/s Self Encrypting Drive
Optical drives
Fixed 12.7 mm SATA optical drive:
  • Blu-ray R/RE DVD+/-RW SuperMulti DL Drive
  • Blu-ray ROM DVD+/-RW SuperMulti DL Drive
  • DVD+/-RW SuperMulti DL Drive
  • DVD-ROM Drive
Second/Third hard drive:
500GB 7200 rpm SMART SATA II Hard Drive
RAID 0 and 1 supported
Weight saver
Memory
Standard:
  • DDR3 PC3-12800 SDRAM (1600 MHz)
  • Two SODIMM slots (Dual-core processor) or four SODIMM slots (Quad-core processor) supporting dual-channel memory
  • 2GB, 4GB, and 8GB SODIMMs
Networking/Communications
Wireless:
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Broadband Wireless (WWAN):
  • HP hs2350 HSPA+ Mobile Broadband Module
  • HP un2430 EV-DO/HSPA Mobile Broadband Module
  • HP lt2522 LTE/EV-DO Mobile Broadband Module (not available at product introduction) - U.S. only5
  • HP lt2523 LTE/HSPA+Mobile Broadband Module (not available at product introduction) - U.S. only5
Integrated wireless LAN options:
  • Intel Centrino Ultimate-N 6300 (3x3)
  • Intel Centrino Advanced-N 6205 (2x2)
  • Broadcom 43224AGN 802.11a/b/g/n (2x2) WiFi Adapter
  • HP Integrated Module with Bluetooth 4.0+EDR Wireless Technology
Communications:
  • Integrated Intel 82579LM Gigabit6 Network Connection (vPro configurations)
  • 56K V.92 modem7
Audio/Multimedia
Audio:
  • SRS Premium Sound PRO (Windows OS only)
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Stereo headphone/line out
  • Stereo microphone/line in
Webcam:
Optional 720p HD webcam
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Ports
  • VGA – One
  • DisplayPort v1.2 – One
  • Stereo microphone in – One
  • Stereo headphone/line out – One
  • Power connector – One
  • Secondary battery connector – One
  • Docking connector – One
  • RJ-45 (Ethernet) – One
  • RJ-11 (Modem) – One
  • 1394a – One
  • USB 3.0 – Two
  • USB 2.0 – Two (one with USB charging port)
  • eSATA/USB 2.0 combo port – One
  • Security lock slot
Digital media slots
  • ExpressCard/54 slot – One (Supports ExpressCard/54)
  • SD/MMC slot – One (Supports SD (Secure Digital), SDHC, SDXC, MMC (MultiMedia Card), MMC+)
  • Integrated Smart Card Reader (Compatible with ISO 7816 compliant Smart Cards PC/SC interface support)
1: Multi-Core is designed to improve performance of certain software products. Not all users or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on the hardware and software configurations. Intel's numbering is not a measurement of higher performance.
2: AMD Eyefinity Technology requires AMD discrete graphics configuration. Total number of screens supported varies by model. HP EliteBook 8570w supports up to five screens.
3: Resolutions are dependent upon monitor capability, and resolution and color depth settings.
4: Up to 19GB is reserved for the system recovery software.
5: Wireless use requires separately purchased service contract. Check with the local vendor for coverage area and availability in your area. Connection and speeds will vary due to location, environment, network conditions, and other factors. 4G compatibility with HSPA+ and LTE. 4G LTE is only available in the United States. LTE is expected to be available in June 2012.
6: The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
7: Designed for downloads from 56K modem compliant sources. Maximum achievable download transmission rates currently do not reach 56 KB/s, and will vary with line conditions. Modem availability is subject to country regulatory approval.
Software overview
Feature
Preinstalled:
  • Genuine Windows 7 Professional 321
  • Genuine Windows 7 Professional 641
  • Genuine Windows 7 Home Premium 641
  • FreeDOS
Supported:
  • Genuine Windows 7 Enterprise 321
  • Genuine Windows 7 Enterprise 641
  • Genuine Windows 7 Ultimate 321
  • Genuine Windows 7 Ultimate 641
  • Genuine Windows XP Professional 32
  • Genuine Windows XP Professional 64
  • SuSE Linux Enterprise Desktop 11 SP2
  • Red Hat Enterprise Linux 6.x
Certified:
Preinstalled software with Windows operating system
  • HP Recovery Manager
  • HP Performance Advisor
  • HP Support Assistant
  • HP ProtectTools Security Manager
  • HP ProtectTools for Central Management
  • HP Hotkey Support
  • HP Power Assistant
  • HP Connection Manager
  • HP GPS and Location (Select Models)
  • Adobe Flash Player
  • Microsoft Office Starter: reduced-functionality Word and Excel only, with advertising. No PowerPoint or Outlook. Buy Office 2010 to use the full-featured software.2
  • Microsoft Security Essentials
  • PDF Complete Special Edition3
  • Corel WinDVD SD (DVD) Player, or HD (Blu-ray) Player (select models)
  • Roxio Secure Burn (select models)
  • Roxio MyDVD Business 2010 (select models)
  • HP Webcam Software (select models)
  • WinZip Basic
Additional software available from the web
HP SoftPaq Download Manager
Security
Standard:
  • HP ProtectTools Security Manager (standard modules include):
    • Credential Manager
    • Computrace Pro
    • Device Access Manager
    • Drive Encryption
    • Face Recognition (webcam configurations only)
    • File Sanitizer
    • Privacy Manager
    • Embedded Security
  • HP Fingerprint Sensor
  • Enhanced Pre-Boot Security (Multiuser/Multifactor)
  • HP Spare Key (requires initial user setup)
  • One-Step Logon
  • TPM 1.2 Embedded Security Chip
  • HP Disk Sanitizer
  • Support for Intel AT
Optional:
  • HP Privacy filter
  • Computrace Pro for HP ProtectTools with GPS tracking
1: Not all features are available in all editions of Windows 7. This system may require upgraded and/or separately purchased hardware to take full advantage of Windows 7 functionality. Click here for details.
2: Includes reduced functionality versions of Word and Excel. Purchase of Product Key required to activate full Office 2010 suite available at participating resellers/retailers and http://www.office.com.
3: PDF Complete Special Edition 60 day trial; purchase license afterwards for full functionality.
Country: Flag Bulgaria
