HP Compaq Pro 6300 Microtower PC Product Specifications
The HP Compaq Pro 6300 Microtower PC
Product features
Feature
Intel Q75 Express
Processor
Intel 3rd generation core i7 processors:
Intel Core i7-3770 processor:
Intel 3rd generation core i5 processors:
  • Intel Core i5-3570 processor
  • Intel Core i5-3470 processor
Intel 2nd generation core i3 processors:
  • Intel Core i3-2130 processor
  • Intel Core i3-2120 processor
Intel Pentium processors:
  • Intel PentiumG870 processor
  • Intel PentiumG860 processor
  • Intel PentiumG640 processor
Intel Celeron processors:
  • Intel Celeron G550 processor
  • Intel Celeron G540 processor
  • Intel Celeron G460 processor
Graphics
Integrated on all models (depends on processor):
Intel HD Graphics: Basic, 2000, 2500, 4000
Optional discrete graphics solutions:
  • AMD Radeon HD 6350 (512MB) PCIe x16 (includes a DMS-59 to Dual VGA Y Cable)
  • AMD Radeon HD7450 (1GB) PCIe x16 (includes a DVI to VGA adapter cable)
  • NVIDIA NVS 300 (512MB) PCIe x16 (Includes a DMS-59 to Dual VGA Y Cable)
  • NVIDIA NVS 310 (512MB) PCIe x16
Adapters and cables:
  • DisplayPort to DisplayPort Cable
  • DisplayPort to DVI-D Adapter
  • DisplayPort to HDMI Adapter
  • DisplayPort to VGA Adapter
Storage
SATA hard drive:
  • 250GB, 7200 rpm, SATA 6.0 Gb/s, SMART IV, 3.5 in
  • 500GB, 7200 rpm, SATA 6.0 Gb/s, SMART IV, 3.5 in
  • 1TB, 7200 rpm, SATA 6.0 Gb/s, SMART IV, 3.5 in
SATA self-encrypting drive:
320GB, 7200 rpm, SATA, 3.5 in
SATA self-encrypting Solid State Drive (SSD):
256GB, SATA, 3.5 in
SATA Solid State Drive (SSD):
  • 120GB, SATA (with 3.5 in adapter)
  • 128GB, SATA (with 3.5 in adapter)
Optical disc drive:
  • DVD-ROM
  • SuperMulti DVD Writer
  • Blu-ray Writer
Media card reader:
22-in-1
Memory1
Type:
  • DDR3 non-ECC
  • Up to 1600 MT/s
Maximum:
32GB
Number of slots:
4
Networking/Communications
Ethernet (RJ-45):
  • Intel 82579LM Gigabit Network Connection (standard)
  • Intel Pro Gigabit CT Desktop PCIe x1 Network Card (optional)
Wireless:
802.11b/g/n PCIe x1 (optional)
Audio/Multimedia
  • High Definition Audio with Realtek ALC221 codec (all ports are stereo)
  • Microphone2 and headphone front ports (3.5 mm)
  • Line-out and Line-In rear Ports2 (3.5 mm)
  • Multi-streaming capable2
  • Internal speaker (standard)
  • Thin USB power speakers
  • USB HD 720P business webcam
  • Business headset
Keyboards and pointing devices
Keyboard:
  • PS/2 keyboard
  • USB keyboard
  • USB Smart Card (CCID) keyboard
  • USB and PS/2 washable keyboard
  • Wireless keyboard and mouse combo
Mice:
  • PS/2 optical mouse
  • USB optical mouse
  • USB laser mouse
  • USB and PS/2 washable mouse
Power
  • 320 W, active PFC, 90% high efficiency
  • 320 W active PFC, standard efficiency
Ports
I/O ports - standard:
  • 4 - USB 3.0 (rear)
  • 4 - USB 2.0 (front)
  • 2 - USB 2.0 (rear)
  • 1 - Serial RS-232 compatible
  • 2 - PS/2 (color-coded support for keyboard (purple) and mouse (green)
  • 1 - VGA
  • 1 - DisplayPort 1.1
  • 1 - Microphone and Headphone (front)
  • 1 - Audio-in and Audio-out (rear)
  • 1 - RJ-45 (accesses the integrated network interface controller)
I/O ports - optional
  • 1 - Parallel
  • 1 - eSATA
Bays
  • 3.5 in external (For Media Card Reader unless used for secondary data drive) - 1 each
  • 5.25 in external - 2 each, 8.19 in depth
  • 3.5 in internal HDD - 2 each
Slots
PCI (5 volt):
  • 1 each
  • 4.2 in full height
  • 6.6 in length
  • 25 W maximum power
PCI Express x1 (2.0):
  • 2 each
  • 6.6 in length
  • 10 W maximum power
PCI Express x16 (3.0 - Primary):
  • 1 each
  • 6.6 in length
  • 725 W maximum power
1: For systems configured with more than 3GB of memory and a 32-bit operating system, all memory may not be available due to system resource requirements. Addressing memory above 4GB requires a 64-bit operating system.
Memory modules support data transfer rates up to 1600 MT/s; actual data rate is determined by the system's configured processor. See processor specifications for supported memory data rate.
2: The front microphone port is re-taskable as a Line-in, Microphone-in or Headphone-out port. Rear audio input ports are re-taskable as a Line-in or Microphone-in port. External speakers must be powered externally. Multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks. This allows for different audio applications to use separate audio ports on the system. For example, the front jacks could be used with a headset for a communications application while the rear jacks are being used with external speakers and a multimedia application.
Physical specifications
Weights and dimensions (configured with 1 HDD and 1 ODD)
Feature
Chassis   (H x W x D)
377 x 177 x 431 mm (14.9 x 7.0 x 17.0 in)
System volume
12.8 L (782.77 cu in)
System weight
9.3 kg (20.5 lb)
Packaging   (H x W x D)
295 x 500 x 590 mm (11.6 x 19.7 x 23.2 in)
Shipping weight
13.1 kg ( 28.8 lb)
Palletization profile
  • 4-units per layer
  • 8-layer maximum
  • 32-units per pallet
Graphics specifications
Intel HD graphics
Feature
VGA controller
Integrated
DisplayPort
  • 1.1a
  • Integrated, multimode capable
  • supports HDCP and audio over DisplayPort
Bus type
PCI Express x16
RAMDAC
  • Integrated
  • 350 MHz
Maximum graphics memory
Microsoft Windows XP:
Up to 1GB
Microsoft Windows 7:
Up to 1.7GB
HW video decode
AVC/VC1/MPEG2/JPEG/MJPEG/PAVP
Maximum color depth
32 bits/pixel
Supported display resolutions and refresh rates1
Resolution
Analog
Digital
640 x 480
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 1024
85
60
1440 x 900
75
60
1600 x 1200
85
60
1680 x 1050
75
60
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
N/A
2048 x 1536
75
N/A
2560 x 1600
N/A
602
1: Other resolutions may be available but are not recommended as they may not have been tested and qualified by HP.
60-R denotes reduced blanking timings are used on single-link DVI connections and may be used with other digital connections.
2: Only supported when using a DisplayPort connection.
AMD Radeon HD 6350 Graphics Card
Feature
Form factor
  • PCI Express x16 (generation 2.0)
  • Low Profile, half length, 2.3 in x 6.6 in
  • Full height bracket utilized when configured to MT
Graphics controller
AMD HD 6350 GPU
Output connector
  • Single DMS-59 connector
  • Supports dual analog displays with included DMS-59 to dual VGA Y cable.
  • Also supports dual digital displays with an optional DMS-59 to dual DVI cable.
Core clock
650 MHz
Memory clock
800 MHz
Memory frame buffer
512MB, DDR3, 64-bit wide
Bus type
  • PCI Express x16
  • Generation 2.0
Maximum vertical refresh
85 Hz
Display support
Integrated 400 MHz RAMDAC
Display maximum resolution
  • Digital 1900 x 1200
  • Analog 2048 x 1536
Maximum power consumption
19.9 W
Supported graphics APIs
  • HDCP supported on DVI output using optional DMS-59 to dual DVI cable.
  • DirectX 11 support in hardware.
  • OpenGL 4.0 support in hardware.
Resolution
Analog
Digital
640 x 480
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 1024
85
60
1440 x 900
75
60
1600 x 1200
85
60
1680 x 1050
75
60
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
N/A
2048 x 1536
75
N/A
2560 x 1600
N/A
N/A
1: 60-R denotes reduced blanking timings are used on single link DVI connections and may be sued with other digital connections.
AMD Radeon HD 7450 Graphics Card
Feature
Form factor
  • Low Profile, half length, 6.57 x 14.48 cm (2.586 x 5.7 in)
Graphics controller
Nvidia GT218 GPU
Output connector
  • Support dual digital displays with an optional adapter.
RAMDAC
Dual 400 MHz
Core clock
520 MHz
Memory clock
790 MHz
Memory frame buffer
512MB DDR3, 64-bit wide
Bus type
  • PCI Express x16
  • Generation 2.0
85 Hz
Display support
19.9 W
Resolution
Analog
Digital
640 x 480
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 1024
85
60
1440 x 900
75
60
1600 x 1200
85
60
1680 x 1050
75
60
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
602
2048 x 1536
75
602
2560 x 1600
N/A
603
2: Only supported with a Display Port monitor connection.
3: Only supported when using a dual link DVI or DP monitor connection.
NVIDIA NVS 300 Graphics Card
Feature
Form factor
  • Low Profile, half length, 2.3 x 6.6 in
Graphics controller
AMD HD 7450 GPU (based on AMD Radeon HD 6000 series technology)
Output connector
Dual-link (DL) DVI-I and DisplayPort output ports
Core clock
625 MHz
Memory clock
800 MHz
Memory frame buffer
1GB, DDR3, 64-bit wide
Maximum pixel clock (analog)
400 MHz
Overlay planes
One 16-bit video overly plane
Video acceleration
  • Directx 10.1
  • OpenGL 3.3
  • CUDA
  • DirectCompute
Supported Graphics APIs
  • OpenGL 3.3 support in hardware
  • DirectX 10.0 support in hardware
High-definition Video Processor (HDVP)
  • Inbuilt video decoder for multiple video formats including MPEG2, VC-1, WMV9, H.264, and MVC
  • Capable of decoding dual Video Streams at HD (1080p) resolutions
  • Hardware color-space conversion (YUV 4:2:2 and 4:2:0)
  • High-Quality in-built Filtering/Scaling
  • Stereo & HD Audio (LPCM 7.1) support for HDMI outputs (HDMI via optional DVI-HDMI dongles) with the DMS-59 to DisplayPort Adapter
Resolution
Analog
Digital
640 x 480
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 1024
85
60
1440 x 900
75
60
1600 x 1200
85
60
1680 x 1050
75
60
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
602
2048 x 1536
75
602
2560 x 1600
N/A
603
NVIDIA NVS 310 Graphics Card
Feature
Bus type
PCI Express x16
Graphics chip
GT218
Core clock
589 MHz
Memory clock
790 MHz
Frame buffer
512MH DDR2, 64-bit wide
Audio support
  • Audio supported through DisplayPort only
  • Integrated HD audio codec supports linear PCM and Dolby Digital (7.1) audio formats
Maximum power
25 W
Dimensions
68.90 x 167.65 mm (2.71 x 6.6 in)
Maximum vertical refresh rate
85 Hz
Display support
  • Digital 2560 x 1600
Board display options
Supports two displays via dual DisplayPort connectors
Resolution
Analog
Digital
640 x 480
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 1024
85
60
1440 x 900
75
60
1600 x 1200
85
60
1680 x 1050
75
60
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
NA
2048 x 1536
75
NA
2560 x 1600
N/A
602
2: Only supported when using a dual-link DVI or DP connection.
Hard disk and solid state storage specifications
Storage drive support
Feature
MCR
ODD
HDD
Number of supported devices
1
2
2
Drive position
3
1,2
4,5
Controller
Feature
Hard drive controller
These systems provide four serial ATA (SATA) interfaces that support transfer rates up to 6.0 Gb/s (for ports 0 and 1, 3 Gb/s on all others). These systems can also support an external SATA (eSATA) device through an optional bracket/cable assembly.
SATA interfaces
  • 2 ea. SATA 3.0
  • 1 ea. SATA 2.0
  • 1 ea. eSATA
Host SATA controller
Advanced Host Controller Interface (AHCI) Revision 1.2. The specification includes a description of the hardware/software interface between system software and the host controller hardware.
HP 250-GB 7200rpm SATA 6.0 Gb/s 3.5 in Hard Disk Drive
Feature
Capacity
250,059,350,016 bytes
Rotational speed
7,200 rpm
Interface
Serial ATA 3.0 (6.0 Gb/s)
Buffer size
8MB
Logical blocks
488,397,168
Seek time (typical reads, includes controller overhead, including settling)
  • Single track: 1.0 ms
  • Average: 8.5 ms
  • Full-stroke: 18 ms
Height (nominal)
2.54 cm (1 in)
Width (nominal)
  • Media diameter: 8.89 cm (3.5 in)
  • Physical size: 10.2 cm (4 in)
Operating temperature
5° to 55°C (41° to 131°F)
HP 500-GB 7.2K rpm SATA 6.0 Gb/s 3.5 in Hard Disk Drive
Feature
Capacity
500,107,862,016 bytes
Rotational speed
7,200 rpm
Interface
Buffer size
16MB
Logical blocks
976,773,168
  • Single track: 2.0 ms
  • Average: 11 ms
  • Full-stroke: 21 ms
Height (nominal)
2.54 cm (1 in)
Width (nominal)
HP 1-TB 7.2K rpm SATA 6.0 Gb/s 3.5 in Hard Disk Drive
Feature
Capacity
1,000,204,886,016 bytes
Rotational speed
7,200 rpm
Interface
Buffer size
32MB
Logical blocks
1,953,525,168
  • Average: 11 ms
Height (nominal)
2.54 cm (1 in)
Width (nominal)
HP 120-GB Solid State Drive
Feature
Unformatted capacity
120GB
Architecture
Multi Level Cell (MLC) NAND Flash with wear leveling 10 channel controller
Interface
Serial ATA 2.0 (3.0 Gb/s)
Dimensions (W x H x D)
6.98 x 0.95 x 10.2 cm (2.74 x 0.37 x 4 in)
80 g (0.18 lb)
Bandwidth performance
  • Sustained sequential read: Up to 250 MB/s
  • Sustained sequential write: Up to 70 MB/s
  • Random read: Up to 35K IOPs
  • Random write: Up to 6.6K IOPs
Latency
  • Read: 65 ms
  • Write: 85 ms
Power
  • DC power requirement: 5 V dc 5%-100 mV ripple p-p
  • Total power consumption: 0.15 W (active); 0.075 W (idle)
Useful drive life
  • 35TB written
  • up to 20 GB/day for 5 years
Environmental (all conditions, non-condensing)
Operating temperature:
0° to 70°C (32° to 158°F)
Relative humidity:
5% to 95%
Maximum wet bulb temperature (operating):
29°C (84°F)
Shock:
1,500G/1.0 ms
HP 128 GB Solid State Drive (SSD)
Feature
128GB1
Architecture
Interface
SATA 6 GB/sec
6.985 x 0.7 x 10.05 cm (2.75 x 0.276 x 3.96 in)
73 g (0.16 lb)
  • Sustained sequential read: Up to 450 MB/s
  • Sustained sequential write: Up to 260 MB/s
  • Random read: Up to 46K IOPs
  • Random write: Up to 56K IOPs
Latency
  • Read: 55µs (TYP)
  • Write: 55µs (TYP)
Power
  • Min 4.5 V
  • Max 5.5 V
  • 160 mW (Active)
  • <85 mW 85 mW (Idle)
Useful drive life
1.2 million device hours2
Relative humidity:
5% to 95%
29°C (84°F)
Shock:
1,500G/0.5 ms
Regulations
  • UL
  • CSA
  • EN 60950-2000
  • CISPR Pub 22 Class B
  • CNS 13438
  • AS/NZS CISPR 22:2002 Class B
  • Korea KCC
  • CE Mark
Option kit contents
  • HP 128GB Solid State Drive (SSD)
  • Documentation
  • 3.5-inch bay adapter bracket
  • 3.5-inch bay adapter bracket screws
  • SATA cable
1: For solid state disk drives, GB means 1 billion bytes. 128GB is the unformatted capacity of this drive before a portion of the drive is reserved for flash management features. Actual capacity will vary by content.
2: The product achieves a mean time between failure (MTBF) based on population statistics not relevant to individual units.
Removable storage specifications
HP Blu-ray writer drive
Feature
AMO part number
AR482AA
Height
  • 5.25-inch
  • Half-height
  • Tray-load
Orientation
Either horizontal or vertical
Interface type
SATA
Disc capacity
50GB DL or 25GB standard
15.0 x 4.4 x 19.0 cm (5.9 x 1.7 x 8.0 in)
Weight (max)
907 g (2.0 lb)
Disc capacity
DVD-ROM: 8.5GB DL or 4.7GB standard
Blu-ray: 50GB DL or 25GB standard
Full stroke DVD: <250 ms (seek)
Full stroke CD: < 210 ms (seek)
Blu-ray: <275 ms (seek)
Startup time (Time to drive ready from tray loading):
  • BD-ROM (SL/DL) 25S/28S
  • BD-R (SL/DL) 25S/28S
  • BD-RE (SL/DL) 25S/28S
  • DVD-ROM (SL/DL) 18S/18S
  • DVD-R (SL/DL) 25S/25S
  • DVD-RW 25S
  • DVD+R (SL/DL) 25S/25S
  • DVD+RW DVD+RW 25S
  • DVD-RAM 45S
  • CD-ROM 15S
Maximum data transfer rates
CD-ROM read:
  • CD-ROM up to 40X
  • CD-R up to 40X
  • CD-RW up to 40X
DVD-ROM read:
  • DVD-RAM up to 5X
  • DVD+RW up to 10X
  • DVD-RW up to 10X
  • DVD+R DL up to 8X
  • DVD-R DL up to 8X
  • DVD-ROM up to 16X
  • DVD-ROM DL up to 8X
  • DVD+R up to 12X
  • DVD-R up to 12X
Blu-ray:
  • BD-ROM up to 6X
  • BD-ROM DL up to 4.8X
  • BD-R up to 6X
  • BD-R DL up to 4.8X
  • BD-R up to 6X
  • BD-RE SL/DL up to 4.8X
Power
Source:
SATA DC power receptacle
  • 5 V dc ± 5%-100 mV ripple p-p
  • 12 V dc ± 5%-200 mV ripple p-p
DC current:
  • 5 V dc -1000 mA typical
  • 1600 mA maximum 12 V dc -600 mA typical
  • 1400 mA maximum
Environmental (all conditions non-condensing)
Temperature (operating):
5° to 50°C (41° to 122°F)
Relative humidity (operating):
10% to 90%
30°C (86°F)
HP SuperMulti DVD writer drive
Feature
AMO part number
AR630AT
Height
  • 5.25-inch
  • Half-height
  • Tray-load
Orientation
Interface type
Serial ATA
15.0 x 4.4 x 20.3 cm (5.9 x 1.7 x 8.0 in)
Weight (max)
1.2 kg (2.6 lb)
Performance
CD Media Read Access:
  • Random: <120 ms typical
  • Full stroke: <200 ms typical
DVD Media Read Access:
CD Media Read Transfer:
  • Digital Audio Extraction (CD-ROM, CD-R):
    Up to 6000 KB/s (40X)
  • Digital Audio Extraction (CD-RW):
    Up to 4800 KB/s (32X) Video CD Playback Up to 2400 KB/s (16X)
DVD Media Read Transfer:
  • DVD-ROM SL Read: Up to 21600 KB/s (16X)
  • DVD-ROM DL Read: Up to 10800 KB/s (8X)
  • DVD Video Playback: Up to 10800 KB/s (8X)
  • DVD Video SL (other than playback): Up to 21600 KB/s (16X)
  • DVD Video DL (other than playback): Up to 10800 KB/s (8X)
  • DVD-R: Up to 21600 KB/s (16X)
  • DVD+R: Up to 21600 KB/s (16X)
  • DVD-RW: Up to 10800 KB/s (8X)
  • DVD-R DL: Up to 10800 KB/s (8X)
  • DVD+RW: Up to 10800 KB/s (8X)
CD Media Write Transfer:
  • CD-R Write: Up to 6000 KB/s (40X)
  • CD-RW: 600 KB/s (4X)
  • CD-RW (High speed): 1500 KB/s (10X)
  • CD-RW (Ultra speed): Up to 3600 KB/s (24X)
  • CD-RW (Ultra speed+): Up to 4800 KB/s (32X)
DVD Media Write Transfer:
  • DVD+R DL (v1.2): Up to 16200 KB/s (12X)
  • DVD+R DL (v1.1): Up to 10800 KB/s (8X)
  • DVD+RW (Volume 2 v1.0): Up to 10800 KB/s (8X)
  • DVD+RW (Volume 1 v1.3): Up to 5400 KB/s (4X)
  • DVD-R (v2.1 rev. 6.0): Up to 16200 KB/s (12X)
  • DVD-R (v2.1 rev. 4.0): Up to 21600 KB/s (16X)
  • DVD-R DL (v3.0 rev. 5.0): Up to 10800 KB/s (8X)
  • DVD-R DL (v3.0 rev. 3.0): Up to 10800 KB/s (8X)
  • DVD-RW (v1.2 rev. 3.0) 8100 KB/s (6X)
  • DVD-RW (v1.2 rev. 2.0): Up to 5400 KB/s (4X)
  • DVD-RAM (v2.2 rev. 5.0): Up to 16200 KB/s (12X)
  • DVD-RAM (v2.2 rev. 2.0): Up to 6750 KB/s (5X)
Media compatibility
Media
Read
Write
CD-ROM
Yes
No
CD-R
Yes
No
CD-RW
Yes
No
DVD-ROM
Yes
No
DVD-ROM DL
Yes
No
DVD-RAM
Yes
No
DVD+R
Yes
No
DVD+R DL
Yes
No
DVD+RW
Yes
No
DVD-R
Yes
No
DVD-RW
Yes
No
DVD-R DL
Yes
No
Power supply
Source
5 V dc ± 5%
100 mV ripple p-p
12 V dc ± 5%
200 mV ripple p-p
DC Current
5 V dc
<1000 mA (typical) 1600 mA (max.)
12 V dc
1200 mA (typical) 2000 mA (max.)
Rear panel
  • SATA Power Connector, 15-pin
  • SATA Data Connector, 7-pin
  • Markings to identify each connector
Environmental conditions (all conditions non-condensing)
Storage temperature:
-30°C to 60°C (-22°F to 140°F)
Relative humidity:
10% to 90%
Maximum wet bulb temperature:
30°C (86°F)
Altitude:
0 to 3,100 meters (0 to 10,171 ft.)
HP DVD-ROM drive
Feature
AMO part number
AR629AA
Height
  • 5.25-inch
  • Half-height
  • Tray-load
Orientation
Interface type
Serial ATA
14.8 x 4.2 x 17.5 cm (5.8 x 1.7 x 6.9 in)
Weight (max)
950 kg (2.1 lb)
Performance
  • Random: <130 ms typical
  • Full stroke: <240 ms typical
  • Digital Audio Extraction (CD-ROM, CD-R): Up to 6000 KB/s (40X)
  • Digital Audio Extraction (CD-RW): Up to 4800 KB/s (32X) Video CD Playback Up to 2400 KB/s (16X)
  • Video CD Playback: Up to 2400 KB/s (16X)
Media compatibility
Media
Read
Write
CD-ROM
Yes
No
CD-R
Yes
No
CD-RW
Yes
No
DVD-ROM
Yes
No
DVD-ROM DL
Yes
No
DVD-RAM
Yes
No
DVD+R
Yes
No
DVD+R DL
Yes
No
DVD+RW
Yes
No
DVD-R
Yes
No
DVD-RW
Yes
No
DVD-R DL
Yes
No
Power supply
Source
5 V dc ± 5%
100 mV ripple p-p
12 V dc ± 5%
200 mV ripple p-p
DC Current
5 V dc
12 V dc
Total Drive Power (Standby Mode)
<2.5 W
Rear panel
Relative humidity:
10% to 90%
30°C (86°F)
Altitude:
HP 22-n-1 Media Card Reader
Feature
USB interface
USB 2.0 High-speed interface1
Advance protocol support
  • Supports hardware ECC (Error Correction Code) function
  • Supports hardware CRC (Cyclic Redundancy Check) function
  • Supports MS 4-bit parallel transfer mode
  • Supports MS-PRO 4-bit parallel transfer mode
  • Supports MS PRO-HG Duo 4-bit parallel transfer mode
  • Supports SD 4-bit parallel transfer mode
  • Supports high-speed 50 Mhz SD 4-bit card (version 2.0)
  • Supports high-speed 52 Mhz MMC 8-bit card (version 4.2)
  • Supports CF v4.0 with PIO mode 6 and Ultra DMA mode
Supported media type
  • CompactFlash Type I
  • CompactFlash Type II
  • Microdrive MultiMediaCard (MMC)
  • Reduced Size MultiMediaCard (RS MMC)
  • MultiMediaCard 4.2 (MMC Plus, including MMC Plus HC)
  • Reduced Size MultiMediaCard 4.2 (MMC Mobile, including MMC Mobile HC)
  • Secure Digital Card (SD)
  • Secure Digital High Capacity (SDHC)
  • miniSD
  • miniSD High Capacity
  • Micro SD (T-Flash)
  • Micro SD HC
  • Memory Stick
  • Memory Stick Select
  • Memory Stick Duo (MS Duo)
  • Memory Stick PRO (MS PRO)
  • Memory Stick PRO Duo (MS PRO Duo)
  • Memory Stick PRO-HG Duo
  • MagicGate Memory Stick (MG)
  • MagicGate Memory Stick Duo
  • xD-Picture Card
Supported media type with card adapter
  • Memory Stick Micro (M2)
  • MMC Micro
Environmental
Operational environmental extremes:
Test parameters/conditions - Power applied, unit operating on system ±5% nominal supply voltage.
  • 10°C 10% R.H. <= 24 hours
  • 10°C 90% R.H. <= 24 hours
  • 20°C 90% R.H. <= 24 hours
  • 30°C 90% R.H. <= 24 hours
  • 40°C 90% R.H. <= 24 hours
  • 50°C 90% R.H. <= 24 hours
  • 50°C 10% R.H. <= 24 hours
Storage environmental extremes
Test parameters/conditions:
  • 60°C (140°F) @ 80% R.H. for 96 hours
  • -30°C (-22°F) @ 20% R.H. for 48 hours
  • No power applied
  • Delta °C < 1.0°C/min
  • Delta % R.H. < 1.5% R.H./min
Approvals
  • USB-IF
  • WHQL
  • Compliant with USB Mass Storage Class Bulk only Transport Specification Rev. 1.0
  • Compliant Intel Front Panel I/O Connectivity Design Guide V. 1.3
  •   FCC
  • CE
  • BSMI
  • C-Tick
  • VCCI
  • MIC
  • cUL
  • TUV-T
1: USB 2.0 High-speed interface.
Memory specifications
Slot 1 is black and must always be populated. Not all memory configurations possible are represented below:
Memory configurations
Total Memory
Socket
Channel A
Channel B
1 (black)
2 (white)
3 (white)
4 (white)
2GB
2GB
unpopulated
unpopulated
unpopulated
4GB (dual channel)
2GB
unpopulated
2GB
unpopulated
8GB (dual channel)
2GB
2GB
2GB
2GB
16GB (dual channel)
8GB
4GB
4GB
4GB
You must shut down the computer and disconnect the power cord before adding or removing memory modules. Regardless of the power-on state, voltage is always supplied to the memory modules as long as the computer is plugged in to an active AC outlet. Adding or removing memory modules while voltage is present may cause irreparable damage to the memory modules or system board.
Network specifications
Intel 82579LM GbE Network Connection (integrated)
Feature
Connector
RJ-45
System interface
Integrated on PCA
Controller
Intel 82579LM GbE platform LAN connect networking controller
Memory
24KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mb/s
IEEE compliance
  • 802.1P
  • 802.1Q
  • 802.2
  • 802.3
  • 802.3ab
  • 802.3az
  • 802.3u
Bus architecture
PCI Express and SMBus
Data transfer mode
PCIe-based interface for active state operation (S0 state) and SMBus for host and management traffic (Sx low power state)
Power requirement
Requires 3.3 V and 1.05 V or just 3.3 V with integrated regulators Power consumption 0.697 W
Boot ROM support
Yes
Network transfer mode
  • Full-duplex
  • Half-duplex (not supported for the 1000BASE-T transceiver)
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mb/s
  • 10BASE-T (full-duplex) 20 Mb/s
  • 100BASE-TX (half-duplex) 100 Mb/s
  • 100BASE-TX (full-duplex) 200 Mb/s
  • 1000BASE-T (full-duplex) 2000 Mb/s
Environmental
0° to 85°C
Operating Humidity:
60% RH
Management
  • WOL
  • auto MDI crossover
  • PXE
  • Muti-port teaming
  • RSS
  • Advanced cable diagnostic.
Alerting
  • ASF 2.0 support
  • AMT 7.0 support
Intel Gigabit CT Desktop Network Interface Controller
Feature
Connector
RJ-45
System interface
PCI Express x1
Controller
Intel WG82574L Gigabit Ethernet Controller
Memory
Integrated Dual 48K configurable transmit receive FIFO Buffers
10/100/1000 Mb/s
IEEE compliance
  • 802.1P
  • 802.1Q
  • 802.2
  • 802.3
  • 802.3AB and 802.3u compliant
  • 802.3x flow control
Bus architecture
PCI-E 1.0a
Data path width
  • X1
  • 250 MB/s
  • Bi-directional interface
Data transfer mode
Bus-master DMA
Hardware certifications
  • FCC
  • B
  • CE
  • TUV- cTUVus Mark Canada and United States
  • TUV- GS Mark for European Union
Power requirement
Aux 3.3 V, 3.0 W in 1000base-T and 2.0 W in 100Base-T
Boot ROM support
Yes
  • 1000BASE-T (full-duplex) 2000 Mb/s (actual rate limited by PCI Bus)
Environmental
0° to 55°C (32° to 131°F)
Operating humidity:
85% at 55°C (131°F)
Management
  • WOL
  • PXE
  • DMI
  • WFM 2.0
Dimensions
12.1 x 5.7 x 2.0 cm (4.75 x 2.25 x 0.8 in)
Feature
Dimensions (L x H)
7.0 x 5.7 cm (2.8 x 2.2 in)
40 g (0.08 lbs)
Controller
Ralink RT2790
System interface
PCI Express x1
Network standard
802.11 b/g/n
Frequency band
2.400 - 2.497 GHz
-10° to 65°C, operating (14° to 149°F, operating)
Storage temperature
-40° to 80°C, non-operating (-40° to 176°F, non-operating)
Humidity
  • 10 - 90% operating
  • 5 - 95% non-operating
Operating voltage
  • 3.3 V +/- 9%
  • 12 V +/- 8%
Power consumption
Platform/WLAN Mode
Power Consumption
Maximum Power Consumption
10 W
Transmit Only
4 W maximum averaged power over 1 second
Transmit Packet or Active Scanning
1000 mA peak current for 100 ms or longer
Receive Only Mode or Idle without IEEE PSP mode enabled
3 W maximum averaged over 1 second
Idle, with IEEE PSP mode enabled
1.0 W maximum averaged over 1 second
Transmit Disabled (turned off in software)
50 mW maximum, averaged over 1 secon
Platform in S3 or S4 (power removed from Low Profile PCI Express Card)
5 mW maximum, averaged over 1 second
Output power (approximate)
802.11b mode: +19 dBm +/- 1.0 dB maximum
802.11g mode: +17 dBm +/- 1.0 dB maximum
EWC mode: +17 dBm +/- 1.0 dB maximum (total power in all transmit chains)
Security
  • IEEE and WiFi compliant 64/128 bit WEP encryption
  • AES: CCM
  • 802.1x authentication
  • WPA: 802.1x. WPA-PSK and TKIP
  • WPA2 certification
  • IEEE 802.11i Cisco Certified Extensions, all versions through V5
Certifications
Wi-Fi certified
Certifications for use by country
  • United States
  • Canada
  • Peru
  • Taiwan
Audio specifications
High definition audio
Feature
Type
Integrated
HD Stereo codec
Realtek 2-channel ALC221 codec
Audio I/O ports
  • Front microphone-In (150-K ohm Input Impedance)
  • Rear Line-In/Microphone input (150-K ohm Input Impedance, function is configurable by audio driver)
  • Rear Line-Out (190 ohms Output Impedance, expects at least a 10-K ohm load)
  • Front Headphone-Out (0.5 Ohm Output Impedance, expects at least a 32 ohm load)
  • Front Microphone/Headphone jack is re-task able to provide Microphone input, line-in or
  • Headphone output to support connecting two headphones to the front of the system. When configured as a second front headphone output, both front headphone outputs are always driven with the same signal.
  • All ports are 3.5 mm
Internal speaker amplifier
  • 1.5 W amplifier for the internal speaker only.
  • External speakers must be powered externally.
  • Rear Line-in audio port is re-taskable as either Line-in or Microphone-In.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes - Uses OS soft wavetable
Analog audio
Yes
Number of Channels on Line-Out
Stereo (Left & Right channels)
Internal speaker
Yes
External speaker jack
Yes
HP Thin USB powered speakers
Feature
On/Off/Volume controls
Right side of right speaker
Power LED
Front of right speaker (green)
Frequency response
FO to 20 kHz
Watts
2/3 W (normal/maximum)
Dimensions/Speaker (H x W x D)
14.52 x 9.50 x 2.45 cm (5.72 x 3.74 x 0.96 in)
Net weight
0.31 kg (0.68 lbs)
Color
Black
-10° to 40°C (14° to 104°F)
Relative humidity:
40% to 90%
Speaker cable length
  • Input cord: 1800 mm (5.91 ft)
  • L-channel cord: 1000 mm (3.28 ft)
  • USB cord: 1800 mm (5.91 ft)
Software overview
Feature
Operating systems
Preinstalled:
  • Genuine Windows 7 Ultimate (32-bit or 64-bit)
  • Genuine Windows 7 Professional (32-bit or 64-bit)
  • Genuine Windows 7 Home Premium (32-bit or 64-bit)
  • Genuine Windows 7 Home Basic (32-bit)
  • FreeDOS
Supported:
Genuine Windows 7 Enterprise (32-bit or 64-bit)
Limited support:
Genuine Windows XP Professional (32-bit)
Certified:
  • Novell SUSE Linux Enterprise Desktop 11
  • Red Hat Enterprise Linux 64
Test and document:
  • Genuine Windows Vista Enterprise (32-bit or 64-bit)
  • Genuine Windows Vista Professional (32-bit or 64-bit)
Software components
  • Adobe Flash Player
  • Ask Search (alternate search engine)
  • HP Marketplace
  • HP Wallpaper
  • Microsoft Advantage Program, including the following:
    • Bing Bar Toolbar
    • Bing Search
    • Microsoft Internet Explorer Home Page
  • Microsoft Security Essentials
  • PDF Complete Corporate Edition
  • WinZip Basic
  • Yahoo Search (alternate search engine)
Included HP Documentation (eDOCS)
  • HP eHelp Documentation
  • HP Hardware Reference Guide
  • HP Quick Setup & Getting Started Guide
  • HP Regulatory and Safety Information
  • HP Safety and Comfort Guide
  • HP Warranty Documentation
Included HP support applications
  • HP Help and Support
  • HP Recovery Manager
  • HP Support Assistant
Environmental specifications
Feature
Eco-Label certifications and declarations
  • US ENERGY STAR
  • IT ECO declaration
  • EPEAT Gold where HP registers commercial desktop products.
System configuration
  • The configuration used for the Energy Consumption and Declared Noise Emissions data for the Small Form Factor Desktop model is based on a typically configured product.
  • The configuration used for the Energy Consumption and Declared Noise Emissions data for the Microtower Desktop model is based on a typically configured product.
Energy consumption
Feature
115 V ac
230 V ac
100 V ac
Normal operation
48.49 W
49.54 W
47.99 W
 Sleep (Energy Star low   power mode)
1.887 W
2.117 W
1.852 W
Off
0.641 W
0.847 W
0.621 W
Heat dissipation
Feature
115 V ac
230 V ac
100 V ac
Normal operation
166 BTU/hr
169 BTU/hr
164 BTU/hr
 Sleep
6 BTU/hr
7 BTU/hr
6 BTU/hr
Off
2 BTU/hr
3 BTU/hr
2 BTU/hr
Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
Declared noise emissions (in accordance with ISO 7779 and ISO 9296)
Feature
Sound Power (LWAd, bels)
Sound Pressure (LpAm, decibels)
Idle
3.8
28
 Fixed Disk (random writes)
3.9
29
Longevity and upgrading
This product can be upgraded, possibly extending its useful life by several years. Upgradeable features and/or components contained in the product may include:
  • Intel LGA775 processor socket
  • 8 USB ports
  • 1 empty PCI slot (w/ optional PCI riser card) , or
    1 empty PCIe x16 slot (w/optional PCIe riser card)
  • 1 internal drive slot
  • 1 Slimline optical drive slot
  • 3 memory slots
  • 1 Serial/Parallel Port (optional)
Batteries
This battery(s) in this product comply with EU Directive 2006/66/EC.
Batteries used in the product do not contain:
  • Mercury greater the 5 ppm by weight
  • Cadmium greater than 10 ppm by weight
Battery size: CR2032 (coin cell)
Battery type: Lithium
