HP Compaq Elite 8300 PC Product Specifications
Product description
HP Compaq Elite 8300 Series is an elite portfolio of business PC platforms designed around the latest management, security and expansion technologies.
Product features
Feature
Processors
Intel 2nd & 3rd Generation Core i3, i5, i7 Processors; select processors include Intel vPro Technology, Intel Pentium
Intel Q77 Express
Memory
CMT, MT, SFF
1600-MHz non-ECC DDR3 SDRAM; (4) DIMM slots enabling up to 32GB
USDT
1600-MHz non-ECC DDR3 SDRAM; (2) SO-DIMM slots enabling up to 16GB
Internal storage
A full range of hard disk and solid state storage drives, including some with self-encrypting capabilities, in capacities to meet today’s requirements.
Removable storage
Optional optical disc drives and a media card reader supporting data storage and backup, multi-media and software installation.
Input devices
A full range of optional keyboards and mice, including models featuring an integrated SmartCard Reader.
Physical specifications
Convertible Minitower specifications
Specification
Chassis (H x W x D)
44.8 x 17.8 x 44.5 cm (17.6 x 7.0 x 18.0 in)
Approximate weight
11.2 kg (24.5 lb)
Weight supported (maximum distributed load in desktop position)
35 kg (77 lb)
Drive bays
External: (3) 13.33 cm (5.25 in)
Internal: (3) 8.89 cm (3.5 in)
(3) PCI; (1) PCIe x1; (1) PCIe x4; (1) PCIe x16
Temperature range1
Operating
10° to 35°C (50° to 95°F)
Non-operating
-30° to 60°C (-22° to 140°F)
Relative humidity (noncondensing)
Operating
10-90%
Non-operating (38.7°C (101.66°F) max wet bulb)
5-95%
Maximum altitude (unpressurized)
Operating
3,048 m (10,000 ft)
Non-operating
9,144 m (30,000 ft)
Power supply2
Operating voltage range
90-264 V ac
Rated voltage range
100-240 V ac
Rated line frequency
50-60 Hz
Operating line frequency
47-63 Hz
Standard efficiency
320 W
High efficiency
320-W active PFC; 87/90/87% efficient at 20/50/100 % load
Rated input current
5.5 A
1: Operating temperature is derated 1.0°C (50°F) per 304.8 m (1000 ft) to 3,048 m (10,000 ft) above sea level; no direct sustained sunlight. Maximum rate of change is 10°C/hr (50°F/hr). The upper limit may be limited by the type and number of options installed.
2: This system utilizes an active power factor corrected power supply. This allows the system to pass the CE mark requirements for use in the countries of the European Union. The active power factor corrected power supply also has the added benefit of not requiring an input voltage range select switch.
Microtower specifications
Specification
Chassis (H x W x D)
37.7 x 17.7 x 43.1 cm (14.9 x 7.0 x 17.0 in)
Approximate weight
9.3 kg (20.5 lb)
35 kg (77 lb)
Drive bays
External: (2) 13.33 cm (5.25 in); (1) 8.89 cm (3.5 in)
Internal: (2) 8.89 cm (3.5 in)
(1) PCI; (1) PCIe x1; (1) PCIe x4; (1) PCIe x16
Temperature range1
Operating
Non-operating
Operating
10-90%
5-95%
Operating
3,048 m (10,000 ft)
Non-operating
9,144 m (30,000 ft)
Power supply2
90-264 V ac
Rated voltage range
100-240 V ac
50-60 Hz
47-63 Hz
Standard efficiency
320 W
High efficiency
320-W active PFC; 87/90/87% efficient at 20/50/100% load
Rated input current
5.5 A
Small Form Factor specifications
Specification
Chassis (H x W x D)
10.0 x 33.8 x 37.9 cm (4.0 x 13.3 x 14.9 in)
Approximate weight
7.6 kg (16.7 lb)
35 kg (77 lb)
Drive bays
External: (1) 13.33 cm (5.25 in), (1) 8.89 cm (3.5 in)
Internal: (1) 8.89 cm (3.5 in)
Temperature range1
Operating
Non-operating
Operating
10-90%
5-95%
Operating
3,048 m (10,000 ft)
Non-operating
9,144 m (30,000 ft)
Power supply2
90-264 V ac
Rated voltage range
100-240 V ac
50-60 Hz
47-63 Hz
Standard efficiency
240-W active PFC
High efficiency
240-W active PFC; 87/90/87% efficient at 20/50/100% load
Rated input current
4 A
Ultra-Slim Desktop specifications
Specification
Chassis (H x W x D)
6.6 x 25.1 x 25.4 cm (2.60 x 9.90 x 10.00 in)
Approximate weight
3.1 kg (6.8 lb)
35 kg (77 lb)
Drive bays
External: (1) Slim bay, (1) Secure Digital (SD) Reader bay
Internal: (1) 6.35 cm (2.5 in)
(1) Mini PCI Express, (1) MXM, (1) mSATA
Temperature range1
Operating
Non-operating
Operating
10-90%
5-95%
Operating
3,048 m (10,000 ft)
Non-operating
9,144 m (30,000 ft)
Power supply2
90-264 V ac
Rated voltage range
100-240 V ac
50-60 Hz
47-63 Hz
Software overview
Feature
Operating system (pre-installed availability varies by region)
Genuine Windows 7 Ultimate (32-bit)
Genuine Windows 7 Ultimate (64-bit)
Genuine Windows 7 Professional (32-bit)
Genuine Windows 7 Professional (64-bit)
Genuine Windows 7 Home Premium (32-bit)
Genuine Windows 7 Home Premium (64-bit)
Genuine Windows 7 Home Basic (32-bit)
FreeDOS
Microsoft Security Essentials
Microsoft Office Starter: reduced-functionality Word and Excel only, with advertising. No PowerPoint or Outlook.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
