HP 455 Notebook PC Product Specifications
Product description
This value-priced notebook helps professionals get connected. With a durable casing, the HP 455 provides an affordable, mobile notebook with AMD technology and multimedia tools.
Product features
Feature
China Only
Display1
Internal:
14.0-inch diagonal LED-backlit HD anti-glare display
External:
Up to 32-bit per pixel color depth
VGA:
Port supports resolutions up to 2014 x 1536 external resolution @ 60 Hz
HDMI:
  • 1.3 port supports up to 1080p, 1920 x 1080 at 60 Hz
  • 1920 x1200 @ 60 Hz DVI mode
Color
Charcoal grey
Black resin only
Keyboard
Full-sized keyboard with action keys enabling functions directly.
Pointing device
Touchpad with 2-piece pick button with left and right click functions.
Buttons and function keys
  • Multi-touch gestures supported
  • On/Off button
Processor
  • AMD Dual Core E2-1800 (1.7 GHz, 1MB L2 cache, 2 cores)2 APU with Radeon HD 7340 Graphics
  • AMD Dual Core E1-1200 (1.4 GHz, 1MB L2 cache, 2 cores)2 APU with Radeon HD 7310 Graphics
  • AMD Dual Core E300 (1.3 GHz, 1MB L2 cache, 2 cores) 6 APU with Radeon HD 6310 Graphics
AMD A68M
Memory
Standard:
  • DDR3 SDRAM (1600 MHz)3 Two SODIMM slots supporting single channel 2048MB and 4096MB SODIMMs.
  • Standard memory up to 6144MB
Maximum:
Upgradeable to 8192MB with optional 2048/4096MB SODIMMs in slots 1 and 2
Storage
320/500/640/750GB 5400 rpm SMART SATA II
Audio
  • Integrated Altec lansing stereo speakers
  • Integrated microphone
  • High definition audio support
HD webcam
VGA webcam
Wireless
  • Integrated 802.11b/g/n 1x1 wireless LAN module4
  • Bluetooth 2.1 or Bluetooth 4.0 + High Speed (HS)5
Integrated 802.11b/g/n only
Communications
Realtek Ethernet (10/100/1000 NIC)
Antenna
2 antennas
Single
System specifications
Stand-alone power requirements (AC power)
Nominal operating voltage
18.5 V
Average operating power
Integrated graphics: 12.55 W1 AMD E-series platform
Maximum operating power
<65 W
Temperature
Operating
0° to 35°C (32° to 95°F) (not writing optical)
5° to 35°C (41° to 95°F) (writing optical)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
1. EPEAT registration varies by country. Click here for registration status by country. EPEAT status listed above applies to U.S.
Storage and drive specifications
Internal storage
750GB 5400 rpm SATA hard drive
640GB 5400 rpm SATA hard drive
500GB 5400 rpm SATA hard drive
320GB 5400 rpm SATA hard drive
Drive weight
101 g (0.22 lb)
101 g (0.22 lb)
101 g (0.22 lb)
101 g (0.22 lb)
Capacity
750GB
640GB
500GB
320GB
Height
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate - Synchronous (maximum)
300 MB/s (Drive capability)
150 MB/s (Drive capability)
Seek time (typical reads, including settling)
  • Single track - 3 ms
  • Average - 13 ms
  • Maximum - 24 ms
  • Average - 13 ms
  • Maximum - 24 ms
  • Average - 13 ms
  • Maximum - 24 ms
  • Average - 13 ms
  • Maximum - 24 ms
Rotational speed
5400 rpm
5400 rpm
5400 rpm
5400 rpm
Logical blocks
1,465,149,168
1,250,263,728
976,773,168
625,142,448
Operating temperature
0° to 60°C (32° to 140°F) [case temp]
Features
ATA security
ATA security
ATA security
ATA security
Optical drives
Access times
Random
  • < 140 ms CD (typical)
  • < 160 ms DVD (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 5X DVD-RAM
Transfer mode interface
  • UDMA Mode 5
  • Gen 1 SATA
Supported media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multi session CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
Supported media (write)
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
Max media capacity (read)
8.5GB
Max media capacity (write)
8.5GB
Transport
Tray loading
Network/Communication specifications
Networking
Integrated Realtek RTL8161FH-CG 10/100/1000 NIC
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (100BASE-T; IEEE 802.3ab; IEEE 802.3 clauses 21-30) ( Support in RTL8161FH-CG only)
  • Auto-negotiation (automatic speed selection)
  • Full duplex operation at all speeds, half duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x flow control (IEEE 802.3 clauses 31-32; configurable
Power management
  • ACPI compliant - multiple power modes
  • Situation-sensitive features reduce power consumption
  • Advanced link down power saving for reducing link down power consumption
Performance features
  • TCP/IP/UDP checksum offload (configurable)
  • Large send offload and giant send offload
  • Receiving side scaling
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame); Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 remote boot
  • Statistics gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual cable doctor for ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Realtek PCIe FE Ethernet Family Controller
Communication
Athero 802.11b/g/n WiFi adapter
Athero 802.11b/g/n Bluetooth 4.0 combo card
Wireless LAN standards
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Frequency band data rates
  • 2.402 - 2.482 GHz
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: card will support rates for NSS=1 for RX and TX for 20 MHz channels. Short and long guard intervals shall be supported.
  • 2.402 - 2.482 GHz
Frequency support
20 MHz: 2.4 GHz bands
NA
Modulation
  • Direct sequence spread spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security1
  • Supports 64 and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST.
  • Support for Cisco security features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 5) with Microsoft Windows 7 only.
  • Supports 64 and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST. WAPI
  • Support for Cisco security features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 5) with Microsoft Windows Vista and XP only.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (access point required)
Roaming
IEEE 802.11 compliant roaming between access points
Output power2
13.5 dBm, minimum
13.5 dBm, minimum
Power consumption
  • Idle associated: 250 mW avg (CLKREQ enabled)
  • Idle unassociated: 100 mW avg
  • Transmit/Receive channel: 2.0 /1.6 W
  • Idle unassociated: 150 mW
  • Transmit/Receive channel: 2.0 /1.6 W (max)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity3
72.2 Mb/s: -71dBm
  • 54 Mb/s: -62 dBm
  • 11 Mb/s: -82 dBm
  • 1 Mb/s: -89 dBm
Antenna type
High efficiency dual antenna with spatial diversity, usually mounted in the display enclosure.
Form factor
PCI-Express Half-MiniCard
4 g
6 g
Dimensions
3.3 x 26.65 x 29.85 mm (0.13 x 1.05 x 1.17 in)
Operating voltage
3.3 v +/- 9%
3.3 v +/- 10%
Temperature
Operating: -10° to 70°C (14º to 158ºF)
Non-operating: -40° to 80° C (40° to 176°F)
Operating: -10° to 65°C (14° to 149°F)
Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
Operating: 10% to 90% (non-condensing)
Non-operating: 5% to 95% (non-condensing)
Altitude
Operating: 3,048 m (0 to 10,000 ft)
Non-operating: 15,240 m (0 to 50,000 ft)
Operating: 3,048 m ( 0 to 10,000 ft)
LED activity
Amber LED on - Radio OFF
White LED on - Radio ON
LED Off - Radio OFF
Solid LED On - Radio ON
Bluetooth specification
V4.0 high speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous connection oriented links up to 3, 64 kb/s, voice channels
  • Asynchronous connection less links 2178.1 kb/s/177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep <17 mW
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth software
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power management
  • Microsoft Windows ACPI and USB Bus support.
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park and Sniff.
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth profiles supported
  • Generic Access Profile (GAP)
  • Service Discovery Application Profile (SDAP)
  • Serial Port Profile (SPP)
  • Dial_Up Networking Profile (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Basic Printing Profile (BPP)
  • VDP (Video Distribution Profile)
  • AVRCP (Audio Video Remote Control Profile)
1. Check latest software/driver release for updates on supported security features.
2. Maximum output power may vary by country according to local regulations.
3. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista and Win 7.
Audio/Multimedia specifications
Audio
Implementation
Realtek ALC3201-GR high definition audio
Volume controls
Up, down, and mute function keys
Full duplex
Yes
Microphone In
Stereo
Headphone/Line out
Stereo
Yes
Audio output quality
Frequency response
10 Hz ~ 22 KHz
Signal to noise ratio
Typical 95 dB FSA (DAC)
Total harmonic distortion
Typical -88 dB FS (DAC)
Noise floor
-110 dB
Play/Record
Up to 192 KHz
Sampling rate(s)
  • DAC: 24 bits
  • ADC: 24 bits
Integrated stereo speakers
  • Power rating: 1.5 W
  • Impedance: 4 ohms
Multimedia
Integrated VGA webcam
  • Supports video conferencing and still image capture.
  • Improved quality for video streaming and still image capture (640x480 resolution)
  • Up to 24 frames/sec
  • Fixed focus lens
Electrical specifications
HP 65 W AC Adapter
Dimensions
10.7 x 4.7 x 3.0 cm (4.21 x 1.85 x 1.18 in)
280 g (0.62 lb)
Input
100 to 240 V ac
Input Efficiency
87% min at 115 V ac
Input frequency range
47 to 63 Hz
Input AC current
1.7 A at 90 V ac
Output power
65 W
DC output
18.5 V
Hold-up time
5 msec at 115 V ac input
Output current limit
< 11 A, Over voltage protection - 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating temperature: 5° to 35°C (41° to 95°F)
  • Non-operating (storage) temperature: -20° to 85°C (-4° to 185°F)
  • Altitude: 0 to 1,524 m (0 to 5,000 ft)
  • Humidity: 20% to 95%
  • Storage humidity: 10% to 95%
EMI and Safety certifications
  • CE mark - full compliance with LVD and EMC directives
  • Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
6-Cell (47 WHr) Lithium-Ion battery
Dimensions (H x W x L)
2.17 x 5.23 x 20.5 cm (0.85 x 2.06 x 8.07 in)
0.327 kg (0.7 lb)
Cells/Type
6-cell Lithium-Ion
Watt-hour capacity
47 WHr
Operating (Charging)
0° to 45°C (32° to 113°F)
Operating (Discharging)
-10° to 60°C (14° to 140°F)
Non-operating
Battery re-charge time
  • System in OFF or Standby Mode: 2.5 hours
  • System ON: 3 to 5 hours (depending on system power consumption)
  • HP Fast Charge Technology: Charges the battery up to 90% within 90 minutes when system is OFF
Display specifications
14.0" LED HD BrightView (1366 x 768)
Active area (w x h)
30.9 x 17.4 cm (12.16 x 6.85 in)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
BrightView (glossy)
Contrast ratio
500:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch - 0.252 mm (.009 in)
  • Format - 1366 x 768
  • Configuration - RGB Stripe
Backlight
LED
PPI
112 ppi
Viewing angle
±40° Horizontal, +10°/-30° Vertical (minimum)
40/40/30/10 (Left/Right/Down/Up) (minimum)
Planned industry standard certifications
Certifications
Industry standard certifications
  • UL
  • CSA
  • FCC Compliance
  • ENERGY STAR2
  • EPEAT1
  • ICES
  • Australia / NZ A-Tick Compliance
  • CCC
  • Japan VCCI Compliance
  • KC
  • BSMI
  • CE Marking Compliance
  • BNCI or BELUS
  • CIT
  • GOST
  • Saudi Arabian Compliance (ICCP)
  • SABS
  • UKRSERTCOMPUTER
2. Configurations of the HP 455 that are ENERGY STAR qualified are identified as HP 455 ENERGY STAR on HP websites and on Energy Star website. Click here to access the Energy Star website.
Physical specifications
Dimensions (w x d x h)
34.2 x 23.1 x 3.55 cm (13.46 x 9.09 x 1.40 in)
Starting at 2.0 kg (4.85 lb)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, hard drive, 1GB memory, and optical drive. Weight varies by configuration and components.
Software/OS
Feature
China Only
  • Windows 8
  • Windows 7
  • FreeDos 2.0
  • Ubuntu Linux
  • FreeDos 2.0
  • Ubuntu Linux
Preinstalled software with Windows operating system
  • HP Recovery Manager
  • HP Support Assistant1
  • HP Connection Manager1
  • Cyberlink Power DVD2
  • Cyberlink YouCam DE3
  • Symantec Norton Internet Security 2012 (60-day trial)
Additional software
  • Microsoft Office Starter4: reduced-functionality Word and Excel only, with advertising. No PowerPoint or Outlook. Buy Office 2010 to use the full-featured software.
  • CompuTrace Anti-Theft Absolute Software1 (must be purchased separately)
1. Not available in all regions.
2. Available on select models and not available in all regions.
3. Available on select models.
4. Microsoft Office 2010 Preloaded includes reduced functionality versions of Word and Excel. Purchase of Product Key required to activate full Office 2010 suite available at participating resellers/retailers and at office website. Click here to access the office website.
Computrace agent is shipped turned off, and must be activated by customers when they purchase a subscription. Subscriptions can be purchased for terms ranging from one to five years. Service is limited, check with Absolute for availability outside the U.S.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
