HP LaserJet Enterprise 500 MFP M525 - View or change network settings
Use the HP Embedded Web Server to view or change IP configuration settings.
  1. Print a configuration page, and locate the IP address.
    • If you are using IPv4, the IP address contains only digits. It has this format:
      xxx.xxx.xxx.xxx
    • If you are using IPv6, the IP address is a hexadecimal combination of characters and digits. It has a format similar to this:
      xxxx::xxxx:xxxx:xxxx:xxxx
  2. To open the HP Embedded Web Server, type the IP address into the address line of a Web browser.
  3. Click the Networking tab to obtain network information. You can change settings as needed.
