HP w2371d LCD Monitor - Product Specifications
The HP w2371d is a 58.4 cm (23 inch) LED backlit LCD monitor.
Figure : Photo of the HP w2371d LED backlit LCD monitor
B3A19AA
Features
The w2371d LED backlit LCD monitor has the following features:
  • Supports DVI-D and VGA video input connectors
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Security lock
Technical specifications
LED feature
Specification
Display size
58.4 cm (23 inch) diagonal
Panel active area (width x height): 51 cm x 28.7 cm (20 inches x 11.3 inches)
Display type
TN (LCD) with LED backlighting
Aspect ratio
16:9
Brightness
250 nits
Input terminal
1 DVI-D connector
1 VGA connector
Speakers
None
Scanning frequency
Horizontal scan range 24-94 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle (typical): 170 degrees
Vertical viewing angle (typical): 160 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60Hz (same as max resolution)
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 8,000,000:1
Response time
5 ms
Pixel pitch
0.265mm
Pixels per inch
95.8
Color gamut
72%
HDCP (High-bandwidth Digital Content Protection)
Yes
Power source - AC/DC adapter
Internal power supply
Power consumption: 31 Watts max power consumption (27 Watts typical power consumption) , 0.5 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 5% RH through 95% RH (non-condensing)
Dimensions
H x W x D (unpacked):
39.6 x 55.5 x 18.5 cm (15.6 x 21.9 x 7.3 inches)
Unpacked: 3.4 Kg (7.5 lbs)
