Document ID: c03325229
Version: 1
NOTEBOOK - System BIOS Update F.26 for 8560p, 8460p, 8460w, 6360b, 6460b, 6560b
Release date : 08-May-2012
Last updated : 08-May-2012
DETAILS OF CHANGE
  • Added support for dual USB keyboards in the DOS environment.
  • Added location, manufacturer, size, and speed for each memory slot in the F10 BIOS setup.
  • Added support for Wake on LAN (WOL) with DC power.
  • Fixed an issue where the BIOS cannot be flashed unattended if the BIOS password is larger than 16 characters. This issue occurs only when the BIOS is flashed in delay mode.
  • Fixed an issue where the automatic DriveLock password will not be accepted after a system restart.
  • Fixed an issue where some USB keyboards would not work in the pre-operating system environment.
  • Added a "Require acknowledgment of battery errors" message to keep the 601-602 battery error message displayed during POST until the user acknowledges the message by pressing a key to continue.
  • Fixed an issue where the brightness setting does not restore the original AC setting after removing and reinserting AC during a monitor timeout.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None.
Components affected:
HP Elitebook 8560p Notebook PC, HP EliteBook 8460p Notebook PC, HP Elitebook 8460w Mobile Workstation, HP ProBook 6360b Notebook PC, HP ProBook 6460b Notebook PC, HP ProBook 6560b Notebook PC
DATE OF CHANGE
Effective date : 15-Jun-2012
Hardware platforms affected : HP EliteBook 8460p Notebook PC, HP EliteBook 8460w Mobile Workstation, HP EliteBook 8560p Notebook PC, HP ProBook 6360b Notebook PC, HP ProBook 6460b Notebook PC, HP ProBook 6560b Notebook PC
