HP 650 Notebook PC - Specifications
Physical specifications
Dimensions (w x d x h)
37.6 x 24.7 x 3.58 cm (14.8 x 9.72 x 1.41 in)
Starting at 2.45 kg (5.39 lb)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, hard drive, 1GB memory, and optical drive. Weight varies by configuration and components.
Electrical specifications
Stand-alone power requirements (AC power)
Nominal operating voltage: 18.5 V
Average operating power: Integrated graphics: 12.741 W
Max operating power: <65 W
HP 65 W ac adapter
Input
100 to 240 V ac
Input efficiency: 87% min at 115 V ac
Input frequency range: 47 to 63 Hz
Input AC current: 1.7 A at 90 V ac
Output
Output power: 65 W
DC output: 18.5 V
Hold-up time: 5 msec at 115 V ac input
Output current limit: <11A, Over voltage protection - 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
6-Cell (47 WHr) Lithium-Ion battery
Cells/Type
6-cell Lithium-Ion
Energy temperature
Watt-hour capacity: 47 WHr
Operating (Charging): 0° to 45°C (32° to 113°F)
Operating (Discharging): -10° to 60°C (14° to 140°F)
Non-operating: -20° to 60°C (-4° to 140°F)
Battery re-charge time
System in off or standby mode: 2.5 hours
System ON: 3 to 5 hours (depending on system power consumption)
HP Fast Charge technology: Charges the battery up to 90% within 90 minutes when system is OFF
Display specifications
15.6-inch LED HD (1366 x 768) anti-glare
Active area (w x h)
34.4 x 19.4 cm (13.54 x 7.59 in)
Diagonal size
39.6 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
Pitch: 0.252 mm
Format: 1366 x 768
Configuration: RGB Stripe
Backlight
LED
PPI
101 ppi
Viewing angle
±40° Horizontal, ±10°/-30° Vertical (minimum) 40/40/30/10 (Left/Right/Down/Up)
Storage specifications
750GB 5400 rpm SATA hard drive
640GB 5400 rpm SATA hard drive
500GB 5400 rpm SATA hard drive
320GB 5400 rpm SATA hard drive
Drive weight
101 g (0.22 lb)
101 g (0.22 lb)
101 g (0.22 lb)
101 g (0.22 lb)
Capacity
750GB
6400GB
500GB
320 GB
Height
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum): 300 MB/s (Drive Capability)
Synchronous (maximum): 150 MB/s (Drive Capability)
Seek time (typical reads, including settling)
Single track: 3 ms
Single track: 3 ms
Single track: 3 ms
Single track: 3 ms
Average: 13 ms
Average: 13 ms
Average: 13 ms
Average: 13 ms
Maximum: 24 ms
Maximum: 24 ms
Maximum: 24 ms
Maximum: 24 ms
Rotational speed
5400 rpm
5400 rpm
5400 rpm
5400 rpm
Logical blocks
1,465,149,168
1,250,263,728
976,773,168
625,142,448
Operating temperature
0° to 60°C (32° to 140°F) [case temp]
Features
ATA security
ATA security
ATA security
ATA security
Optical drive specifications
DVD+/-RW SuperMulti DL Drive
Access times
Random
  • <140ms CD (typical)
  • <160 ms DVD (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 5X DVD-RAM
Transfer mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
Supported media (write)
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
Max media capacity (read)
8.5GB
Max media capacity (write)
8.5GB
Transport
Tray loading
Audio/Multimedia specifications
Audio hardware
Implementation
Realtek ALC3201-GR High Definition audio
Volume controls
Up, down, and mute function keys
Full duplex
Yes
Microphone in
Stereo
Headphone/Line out
Stereo
Integrated microphone
Yes
Audio output quality
Frequency response
10 Hz ~ 22 KHz
Signal to noise ratio
Typical 95 dB FSA (DAC)
Total harmonic distortion
Typical -88 dB FS (DAC)
Noise floor
-110 dB
Play/Record sampling rate(s)
Up to 192 KHz
DAC
24 bits
ADC
24 bits
Integrated Stereo Speakers
Power rating
1.5 W
Impedance
4 ohms
Multimedia
Integrated VGA webcam
  • Supports videoconferencing and still image capture
  • Improved quality for video streaming and still image capture (640 x 480 resolution)
  • Up to 24 frames/sec
  • Fixed focus lens
Networking specifications
Integrated Realtek RTL8161FH-CG 10/100/1000 NIC
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (100BASE-T; IEEE 802.3ab; IEEE 802.3 clauses 21-30) (Support in RTL8161FH-CG only)
  • Auto-negotiation (automatic speed selection)
  • Full duplex operation at all speeds, half duplex operation at 10 and 100 Mb/s
  • IEEE 802.1p QoS (Quality of Service) support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x flow control (IEEE 802.3 clauses 31-32; configurable
Power management
  • ACPI compliant - multiple power modes
  • Situation-sensitive features reduce power consumption
  • Advanced link down power saving for reducing link down power consumption
Performance features
  • TCP/IP/UDP checksum offload (configurable)
  • Large send offload and Giant send offload
  • Receiving side scaling
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up frame); Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 remote boot
  • Statistics gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual cable doctor for Ethernet cable status
Interface
PCI express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Realtek PCIe FE Ethernet family controller
Communicaitons specifications
Ralink 802.11b/g/n WiFi adapter
Wireless LAN standards
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Frequency band
2.402 - 2.482 GHz
Data rates
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: card will support rates for NSS=1 for RX and TX for 20 MHz channels. Short and long guard intervals shall be supported.
Frequency support
20 MHz: 2.4 GHz bands
Modulation
Direct sequence spread spectrum
DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security1
Supports 64-bit and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST.
Support for Cisco security features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 5) with Microsoft Windows 7 only.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture
Ad-hoc (Peer to Peer)
Models
Infrastructure (access point required)
Roaming
IEEE 802.11 compliant roaming between access points
Output power2
13.5 dBm, minimum
Power consumption
  • Idle associated: 250 mW avg (CLKREQ enabled)
  • Idle unassociated: 100 mW avg
  • Transmit/Receive channel: 2.0/1.6 W
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity3
72.2 Mb/s: -71dBm
Antenna type
High efficiency dual antenna with spatial diversity, usually mounted in the display enclosure
Form factor
PCI-express half-minicard
4 g
Dimensions
3.3 x 26.65 x 29.85 mm
Operating voltage
3.3 v +/- 9%
Temperature
  • Operating: -10° to 70°C (14° to 158°F)
  • Non-operating: -40° to 80°C (40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
  • Amber LED on-Radio OFF
  • White LED on-Radio ON
Atheros 802.11b/g/n Bluetooth 4.0 combo card
Wireless LAN Standards
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Frequency band
2.402 – 2.482 GHz
Data rates
Modulation
Security1
Supports 64 and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST. WAPI
Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 5) with Microsoft Windows Vista and XP only.
Sub-channels
Models
Roaming
Output power (for CCK)2
13.5 dBm, minimum
Power consumption
  • Idle unassociated: 150 mW
  • Transmit: 2.0 W (max)
  • Receive: 2.0 W (max)
Power management
  • 54 Mb/s: -62 dBm
  • 11 Mb/s: -82 dBm
  • 1 Mb/s: -89 dBm
Antenna type
High efficiency dual antenna with spatial diversity, mounted in the display enclosure
Form factor
6 g
Dimensions
Operating voltage
3.3 v +/- 10%
Temperature
  • Operating: -10° to 65°C (14° to 149°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
Altitude
LED activity
  • LED Off – Radio OFF
  • Solid LED On – Radio ON
Bluetooth (V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0)
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous connection oriented links up to 3, 64 kb/s, voice channels
  • Asynchronous connection less links 2178.1 kb/s / 177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep <17 mW
Antenna
Internally integrated within module
Range
Up to 33 ft (10 m)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software
  • Broadcom bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of bluetooth security provisions
Power management
  • Microsoft Windows ACPI and USB bus support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth profiles supported
  • Generic Access Profile (GAP)
  • Service Discovery Application Profile (SDAP)
  • Serial Port Profile (SPP)
  • Dial_Up Networking Profile (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Basic Printing Profile (BPP)
  • VDP (Video Distribution Profile)
  • AVRCP (Audio Video Remote Control Profile)
  1. Check latest software/driver release for updates on supported security features.
  2. Maximum output power may vary by country according to local regulations.
  3. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista and Win7.
Environmental specifications
Temperature
Operating
  • 0° to 35°C (32° to 95°F) (not writing optical)
  • 5° to 35°C (41° to 95°F) (writing optical)
Non-operating
  • -20° to 60°C (-4° to 140°F)
Relative humidity
Operating
  • 10% to 90%, non-condensing
Non-operating
  • 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
  • 40 G, 2 ms, half-sine
Non-operating
  • 200 G, 2 ms, half-sine
Random vibration
Operating
  • 0.75 grms
Non-operating
  • 1.50 grms
Altitude (unpressurized)
Operating
  • -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
  • -15.24 to 12,192 m (-50 to 40,000 ft)
Standard certifications
Certifications
Planned industry standard certifications
  • UL
  • CSA
  • FCC compliance
  • ENERGY STAR1 (Select models)
  • EPEAT2 (Registered Silver in United States)
  • ICES
  • Australia / NZ A-Tick compliance
  • CCC
  • Japan VCCI compliance
  • KC
  • BSMI
  • CE marking compliance
  • BNCI or BELUS
  • CIT
  • GOST
  • Saudi Arabian compliance (ICCP)
  • SABS
  • UKRSERTCOMPUTER
1. Configurations of the HP 650 that are ENERGY STAR qualified are identified as HP 650 ENERGY STAR on HP websites and on energystar website. Click here to access the energystar website.
2. EPEAT registration varies by country. Click here to see epeat website for registration status by country.
Country: Flag Bulgaria
