HP LV2311 23-inch LED Backlit LCD Monitor - Specifications
Physical specifications
Dimensions (W x D x H)
  • Unpacked w/ stand
    55.45 x 18.52 x 39.62 cm (21.83 x 7.29 x 15.6 in)
  • Unpacked w/o stand (head only)
    55.45 x 5.1 x 34 cm (21.83 x 2 x 13.39 in)
  • Packaged
    61.1 x 42.2 x 11.5 cm (24.1 x 16.61 x 4.53 in)
  • Base area (footprint)
    20 x 18.52 cm (7.87 x 7.29 in)
  • Head only
    3.1 kg (6.83 lb)
  • Unpacked
    3.4 kg (7.5 lb)
  • Packaged
    5.43 kg (11.97 lb)
Color
Black
Technical specifications
On Screen Display (OSD) controls
Buttons or switches
  • Power (on/off)
  • 4-button OSD (Menu, Minus, Plus, OK)
User controls
  • Brightness
  • Contrast
  • Color
  • Image control
  • OSD control
  • Management
  • Language
  • Factory reset
  • Source control
  • Exit
Signal interface/Performance
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
VGA 200 MHz/DVI 170 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Video/Other inputs
Plug and play
Yes
Input connectors
(1) VGA (analog), (2) DVI-D w/HDCP
Input impedance
75 Ohms
Sync input
TTL separate synch
Video cable
VGA
Video cable lengths
1.8 m (6 ft)
Audio
No
VESA external mounting
Yes (one set of standard 4-hole pattern, 75 mm)
Security lock-ready
Yes
Electrical specifications
Input power
90 – 265 V ac, 45 or 63 Hz
Typical power consumption
27 W
Maximum power consumption
31 W
Power saving
< 0.5 W (Sleep)
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Temperature – operating
5° to 35°C (41° to 95°F)
Temperature – non-operating
-20° to 60°C (-4° to 140°F)
Humidity – operating
20% to 80% non-condensing
Humidity – non-operating
5% to 95%, 38.7°C max wet-bulb
Altitude – operating
0 to 5,000 m (16,404 ft)
Altitude – non-operating
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free glass1
Yes
BFR/PVC free2
No
Mercury free
Yes
  1. Arsenic and its compounds were not detected using US EPA Test Methods 3052 & 3052/6010b by ICP or ICP-AES.
  2. Meets the evolving definition of 'BFR/PVC-free' as set forth in the "iNEMI Position Statement on the 'Definition of Low-Halogen' Electronics (BFR/CFR/PVC-Free)'". Plastic parts contain <1000 ppm (0.1%) of bromine [if the Br source is from BFRs] and <1000 ppm (0.1%) of chlorine [if the Cl source is from CFRs or PVC or PVC copolymers]. All printed circuit board (PCB) and substrate laminates contain bromine/chlorine total <1500 ppm (.15%) with a maximum chlorine of 900 ppm (.09%) and maximum bromine being 900 ppm (.09%). External cables (power, video and USB) are not BFR/PVC-free. Service parts after purchase may not be BFR/PVC-free.
Certification and compliance
Certifications
  • Microsoft WHQL
  • CB
  • CE
  • TUV-GS
  • ISO 9241-307
  • CSA
  • FCC
  • GOST
  • NOM
  • TUV-S
  • VCCI
  • KC/KCC
  • PSB
  • ISC
  • CCC
  • BSMI
  • C-TICK
  • CECP
  • SEPA
  • CEL
  • E-standy
  • ENERGY STAR
  • EPEAT Silver1
Compatibility
Compatible with platforms using the VESA standard video modes. Recommended for use with HP products.
1. EPEAT Silver where HP registers commercial display products. Click here to access the registration status in your country.
