Feature
Dimensions (H x W x D)
Unpacked with stand:
Unpacked without stand (head only):
Packaged:
Head only:
Unpacked:
Packaged:
Tilt range
-4° to +18°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Attachable, ships detached
- ${title}
- ${title}
- ${title}
- ${title}
HP S1933 18.5-inch Widescreen LCD Monitor - Specifications
Physical specifications
Panel specifications
Feature
Type
47.0 cm (18.5 in) wide-aspect active matrix Thin Film Transistor (TFT)
Viewable image area
(diagonal)
47.0 cm (18.5 in) widescreen; diagonally measured
Screen opening
(W x H)
40.9 x 23 cm (16.1 x 9.05 in)
Panel type
TN
Aspect ratio
16:9
Viewing angle (typical)
Up to 90° horizontal and 55° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
200 nits (cd/m2)
Contrast ratio (typical)1
600:1
Dynamic contrast ratio (typical)1
5000:1
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.3 mm
Backlight lamp life
(to half brightness)
50,000 hours
Color support
Up to 16.7 million colors
Color gamut
57%
note: |
On Screen Display (OSD) controls specifications
Feature
Buttons or switches
Power, Auto, Menu, +, -
Languages
8 languages (English, Spanish, French, Portuguese, Russian, Simplified Chinese, Traditional Chinese, Korean)
User controls
Brightness, contrast, positioning, color temperature (warm, normal, cool, user SRGB), individual color control, ECO viewing modes, image ratio, clock, clock phase, DDC/CI, reset, language
Signal interface/performance specifications
Feature
Horizontal frequency
30 to 83 kHz
Vertical frequency
55 to 75 Hz
Native resolution
1366 x 768 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
140 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Anti-static
Yes
Default color temperature
Warm (6500 K)
Video/other input specifications
Feature
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
75 ohms
Sync input
TTL separate synch
Video cable
One 15-pin D-sub (VGA)
Video cable lengths
1.8 m (6.0 ft)
Electrical specifications
Feature
Input power
100 to 265 V ac, 50 or 60 Hz
Typical power consumption
23 W
Maximum power consumption
37 W
Power saving
Less than 1 W
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Feature
Operating temperature
5° to 35°C (41° to 95°F)
Non-operating temperature
-20° to +60°C (-4° to +140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 95%
Operating altitude
0 to 3658 m (0 to 12,000 ft)
Non-operating altitude
0 to 12,192 m (0 to 40,000 ft)
Link to product overview information
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Bulgaria
- ${title}
hp-hero-support-search
- ${title}
