HP S1933 18.5-inch Widescreen LCD Monitor - Overview
Product description
The HP S1933 18.5-inch Widescreen LCD Monitor comes with a low power consumption panel that uses less power and contains 50% less mercury, and with the display glass that is arsenic-free.
Product features
Feature
Panel
47.0 cm (18.5 in) wide-aspect active matrix Thin Film Transistor (TFT)
47.0 cm (18.5 in) widescreen; diagonally measured
Screen opening (W x H)
40.9 x 23 cm (16.1 x 9.05 in)
Panel type
TN
Aspect ratio
16:9
Viewing angle (typical)
Up to 90° horizontal and 55° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
200 nits (cd/m2)
Contrast ratio (typical)1
600:1
Dynamic contrast ratio (typical)1
5000:1
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.3 mm
Backlight lamp life (to half brightness)
50,000 hours
Color gamut
57%
Color support
Up to 16.7 million colors
Horizontal frequency
30 to 83 kHz
Vertical frequency
55 to 75 Hz
Native resolution
1366 x 768 @ 60 Hz
User programmable modes
Yes (10)
Anti-glare
Yes
Anti-static
Yes
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
75 ohms
Sync input
TTL separate synch
Tilt range
-4° to +18°
Swivel range
No
Height adjustable
No
Pivot rotation
No
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
