HP LaserJet Pro 400 MFP M425 - Product views
Product front view
    Figure : Front view of product
  1. Document feeder
  2. Dual-head scanner
  3. Output bin
  4. Walk-up USB port
  5. Power button
  6. Tray 2
  7. Tray 1
  8. Front door release button
  9. Color touchscreen control panel
Product back view
    Figure : Back view of product
  1. Rear jam-access door latch
  2. Straight-through paper path door
  3. Hi-Speed USB 2.0 port
  4. Network port
  5. Fax and telephone ports
  6. Power connection
  7. Slot for a cable-type security lock
Serial number and model number location
The serial number and product model number label is on the back of the product.
Figure : Serial number and model number location
Control panel layout
    Figure : Touchscreen layout
  1. Wireless light: indicates the wireless network is enabled. The light blinks while the product is establishing a connection to the wireless network (HP LaserJet Pro 400 MFP M425dw only).
  2. Touchscreen display
  3. Attention light: indicates a problem with the product
  4. Ready light: indicates the product is ready
  5. Help button and light: provides access to the control panel help system
  6. Right arrow button and light: moves the cursor to the right or moves the display image to the next screen
    NOTE: This button illuminates only when the current screen can use this feature.
  7. Cancel button and light: clears settings, cancels the current job or exits the current screen
  8. Back button and light: returns to the previous screen
  9. Left arrow button and light: moves the cursor to the left
  10. Home button and light: provides access to the Home screen
Control-panel Home screen
The Home screen provides access to the product features, and it indicates the product status.
Depending on the product configuration, the features on the Home screen can vary. The layout might also be reversed for some languages.
    Figure : Home screen
  1. Web Services button: provides quick access to HP Web Services features, including HP ePrintHP ePrint is a tool that prints documents by using any email enabled device to send them to the product’s email address.
  2. Setup button: provides access to the main menus
  3. Wireless button: provides access to the Wireless Menu and wireless status information (HP LaserJet Pro 400 MFP M425dw model only)
    NOTE: When you are connected to a wireless network, this icon changes to a set of signal strength bars.
  4. Network button: provides access to network settings and information. From the network settings screen, you can print the Network Summary page.
  5. Information button: provides product status information. From the status summary screen, you can print the Configuration Report page.
  6. Supplies button: provides information about supplies status. From the supplies summary screen, you can print the Supplies Status page.
  7. Fax button: provides access to the Fax feature
  8. Apps button: provides access to the Apps menu to print directly from Web applications that you have downloaded from the HP ePrintCenter Web site at www.hpeprintcenter.com
  9. Product status
  10. Scan button: provides access to the scan feature
  11. Copy button: provides access to the copy feature
  12. USB button: provides access to the USB Flash Drive menu
