    Windows 11 Upgrade Guide
HP LaserJet Pro 400 MFP M425 - Use the HP Reconfiguration Utility to change the product connection
If you are already using the product and you wish to change the way it is connected, use the HP Reconfiguration Utility to set up the connection. For example, you can reconfigure the product to use a different wireless address, to connect to a wired or wireless network, or change from a network connection to a USB connection. You can change the configuration without inserting the product CD. After you select the type of connection you wish to make, the program goes directly to the portion of the product setup procedure that needs to change.
The HP Reconfiguration Utility is located in the HP programs group on your computer.
